95 22re fuel system pressure question
I am attempting to put a new head gasket on my truck, I don't know how to do anything other than a tune up/oil change etc...
The truck does not start so I cannot release the fuel system pressure the way my haynes says. Can I do this by loosening the fuel filter line on the engine side of the fuel filter? I need to remove the intake manifold and exhaust manifold so the book says I need to do this. Any tips would be much appreciated. Thanks
make sure u have the air box connected when starting i made that mistake if u dont it wont start i changed head and tried to start it then i found out there is a sensor in the air chamber on top of the air cleanr that moniters air flow if there is none it kills the ecm this is safty feature in case of acceident
TURBOrunnerNM
07-22-2015 11:01 AM
skoti89
07-08-2015 12:05 AM
