87 pickup 22r carburated - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-01-2009, 08:37 PM   #1 (permalink)
87 toyota pickup 22r carburated exhaust somke when its cold but not after it warms
up
swayin1985 is offline
Old 11-01-2009, 08:44 PM   #2 (permalink)
it is likely the valve stem seals have gone bad, allowing oil to seep into the cylinder while the truck sits, then when you start it up the oil burns off and smokes. Cheap and easy fix, but I never did it on a toyota. On most older engines you take off the valve cover, rocker arm shaft, either move each cylinder to TDC or keep the valve in place by pushing compressed air into the spark plug hole, then take a spring compressor, compress the spring, remove the keeper clips (and dont looose em), then remove the clip or retain spring, replace the seal.
Reassemble is opposite of removal.
predator_machine is offline
Old 11-01-2009, 08:45 PM   #3 (permalink)
Your haynes or chilton's book, or factory service manual can tell you much better than I can. I remember seeing a link to download a factory service manual somewhere on this forum.
Tags
22r, forum, seal, stem, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
