86 Toyota Pickup 22R
Old 08-19-2009, 06:42 AM
nwalkerii's Avatar
Talking 86 Toyota Pickup 22R
Blower motor resister keeps burning out. I've replaced blower motor and switch w/ same results. Is there more to this system? Thanks.
Old 08-21-2009, 01:14 AM
myyota's Avatar
The fan switch and resister are the only two things that i know of that control the fan speed. The resister is mounted in the fan housing to help cool it because it gets hot during use, maybe there are some leaves or other junk in the fan housing blocking the air flow across the resister and after a while the resister gets so hot that it just burns out. Im just throwing out ideas that might possibly be causing the problem your having ?.
Old 08-21-2009, 03:48 AM
Fossilized
Staff
dropzone's Avatar
inspect the wiring to check for a short
Old 08-22-2009, 09:36 PM
wyoming9's Avatar
Red face
You did replace the blower resistor with a new one. I tried a used one it was a waste of time.
The most often just die of old age
Old 08-29-2009, 11:27 AM
nwalkerii's Avatar
I'll check this out. Something is causing the motor (New) to cause the resister to burn out. If I find no blockage, I'll take it to someone who can check the amperage, etc. Thanks so much for your kind response and God bless.
6th Gear
19
12-10-2019 07:31 AM
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
paxanders
06-21-2015 06:29 AM
Quick Reply: 86 Toyota Pickup 22R
