81 toyota pickup will not idle!
Old 05-26-2014, 12:57 PM
Bonzo's Avatar
Its a 22r and i cannot figure out why it will not idle! I took it offroading and it started stuttering at first but now it wont stay idling im at a loss there is no vacuum leaks. It runs fine when you drive it its just when you come to a stop when it has to idle it dies. It doesnt overheat. Any advice would really help.
Old 05-27-2014, 09:45 AM
Staff
kawazx636's Avatar
It looks like you are new here so welcome to the site! You might want to be a little more descriptive in your problem - like Factory carb or Weber? Smogged or desmogged? Mileage? Condition? Etc.
You may be a newbie here, but you'd likely get more responses by posting in the Pre-84 section below instead of the Newbie section:
https://www.yotatech.com/forums/f114/
Here's a start for you, do the easy stuff first to eliminate all the cheap/free variables:
-Check the timing (Per the FSM, it should be 5* BTDC at 950RPM max with the vacuum advanced pinched off - mine likes 8* BTDC, but that is because of a few performance add-ons)
-Check the plugs (could be fouled and/or flooded)
-Check the bowl level on the carb
-Check the fuel pump, lines and filters (unlikely if it runs fine under load)
-Check to make sure that the choke isn't stuck
-Check to make sure the PCV valve isn't stuck (you'd likely have some blow by and burning oil if the PCV isn't working properly)
-Check the A/F mixture on the carb (If it is a stock Aisin, I would do this last since they don't tend to come out of tune and they can be a real PITA to tune if you don't know what you're doing)
Any other symptoms? Like burning oil, blow by, white/blue/black exhaust?
6th Gear
19
12-10-2019 07:31 AM
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
94hiluxZE
06-22-2015 10:42 AM
Quick Reply: 81 toyota pickup will not idle!
