2nd Gen susp. lift comparison/review - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-13-2005, 01:31 PM   #1 (permalink)
hokiruu's Avatar
Hey My name is Uuri I have a 95 runner with totally stock suspension. I have been considering a 3-4" lift for some time now and want to know people's experiences with them all. Alot of the sellers aren't very clear on exactly what is in each one. The ones I am am considering if I don't just go for the little OME are:
Trailmaster
Tuff Country
Pro Comp
Super lift
Downey
AFAIK the Trailmaster and Tuff Country drop down the front arms with extention backets and use longer stiffer springs in back. What are your opinions on these different lifts? can someone who knows please explain the differences between them?
hokiruu is offline
Old 12-13-2005, 03:40 PM   #2 (permalink)
Sponsoring Vendor
Strap22's Avatar
Quote:
Trailmaster
Tuff Country
Pro Comp
Super lift
Downey
This "Little OME" is a great setup. In the picture is 4 Shocks, 2 Coil Springs, Ball Joint spacers, Steering Stabilzer, Rear Coil Spacers. this will give you 3-4" of lift over Factory height. The Downey Pan Hard bracket and Rear Control Arm Truss (Sonoran Steel now offers a much beefier rear truss)are all you need to get you started. I would recommend the PPV bracket and maybe extended brake lines if you use the rear coil spacers and lift the front to be even. The OME setup is a what I run on my '91 2nd Gen. For the price you can't go wrong. Total $614.04
__________________
Phil
Toyota & TRD Parts Wholesale
www.FJCruiserOffroad.com
www.trdparts4u.com
www.toyotapartsales.com
Authorized ARB/OldManEmu Dealer
Authorized OASIS Air Deflators Dealer
Strap22 is offline
Old 12-13-2005, 05:57 PM   #3 (permalink)
Randomness's Avatar
Send a message via AIM to Randomness
I'd recommend Land Cruiser coils in the back, new shocks, BJ spacers, and then a 1-2" BL if needed.
__________________
95 3.slow SR5 4runner
160K miles | 32's | OME | Optima | Husky | dechromed
| ryan |
My Photography
Blog
Randomness is offline
Old 12-13-2005, 07:07 PM   #4 (permalink)
Staff
Lysmachia's Avatar
Send a message via AIM to Lysmachia Send a message via MSN to Lysmachia Send a message via Yahoo to Lysmachia
I've got Landcruiser coils in the back and holy crap do I have articulation!
I only wish ToyTechLifts made stuff for 95 and before. They do 96 and after 4 runners and their lift kits for the 4 runner are 15% off...
http://www.toyteclifts.com/4Runner.html - You still might want to contact Dough at TTL and see if he has anything you could use...
__________________
Molly
aka Lysmachia
93 4 Runner SAS (Tippy) - All Broken in Junk Yard Goodness
Get your 4x4 VIDEO pr0n here
Quote:
Originally Posted by leebee View Post
from this gray haired old red head to you, EGO BOOST!! you go girl!
Lysmachia is offline
Old 12-13-2005, 08:10 PM   #5 (permalink)
tc
tc's Avatar
Do you really need that much lift? What size tires do you want to run?
Here's a good review of how much lift for what tire sizes...
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 12-14-2005, 10:23 PM   #6 (permalink)
hokiruu's Avatar
thanks for the replies guys. for some reason i thought that the OME only was 2-3", but hey 3-4" is good news and actually would probably be enough. I don't think I'll ever run bigger than 33x11.5 or 12.5. For now I only have 31x11.5 Dueler Revos.
One reason I thought I might need some front lift after replacing real coils is that I want to run lower offset wheels. I have been told that even with my current tire size on a lower offset, I run the risk of rubbing. T/F?
The reason I want lower offset is to widen the track in order to add a little stability (especially if I lift it) and for looks. The OME is def. appealing, but I always explore all my options, so I just wanted to know about some of the others. I do not want to add a body lift. If I'm lifting, I want more clearance, plus I am not a big fan of how it looks. I mean, if I HAD to I would but I'd plan in order to avoid it.
hokiruu is offline
Old 12-15-2005, 05:54 AM   #7 (permalink)
tc
tc's Avatar
With less offset (tires stick out more) and wider tires, body contact, not suspension/frame contact will be the issue. The easiest, most cost effective ways to prevent this are trim the fenders and/or a small body lift.
I shared the same opinions about the looks of a body lift until someone on here pointed out how covered the frame is on Toyota trucks and I looked at my 'runner with that in mind. It's not like American trucks where any body lift is going to show the gap between the frame and body. A 1" body lift will hardly show any frame - actually just enough to weld on some sliders.
Personally, I totally agree with the "as little as you can" lift philosophy, and it seems the best way to do this is combine a relatively small suspension lift and body lift.
Sticking with a narrower tire solves a lot of these problems too. I am getting some 33x10.50's this week (no lift in front, just fixed saggy springs in rear), there's another guy on here running 35x10.50's with little/no lift. I will probably do a 1" 4Crawler body lift this summer - too cold for that kind of work here now!
__________________
tc is offline
Old 12-15-2005, 06:51 AM   #8 (permalink)
Doc279's Avatar
Quote:
Hey Randomness,
What model Land Cruiser coils ?
I already have the ball joint spacers
and a 1" body lift - currently using Downey HD rear coils
__________________
"Life's to short !!! Let's drink a couple - cold beers !
1985 4 runner - pretty much stock but it kicks butt stock !!!!!!!!
30" bridgestone duellers on black steelies.
More to come !
Doc279 is offline
Old 12-16-2005, 09:55 AM   #9 (permalink)
AUYota's Avatar
Send a message via AIM to AUYota
check out 4Crawler lifts! His lifts seem to be more Toyota based than others
Go for some 1.5" ball joint spacers up front, and rise the torsion bar about .5-1"
http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
plus some spring spacers in the rear
http://www.4crawler.com/4x4/ForSale/...ngSpacer.shtml
Then consider a good body lift. A one inch body lift after the above is a NICE lift. After a 2" body lift you'll need more work done.
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
After that you can use 33" tires which also give an inch so that is 2+1+1= 4" Also the 33" 10.50's run alot better than the 11.50's in my opinion and the 11.50's don't really help all that much. You can't run 12.5 on stock rims, and I'm not a fan of changing rims. Don't get much good out of it for the cost, and trouble IMO.
AUYota is offline
Old 12-18-2005, 01:49 AM   #10 (permalink)
Keggo's Avatar
Search for a thread made by me... I give part numbers on landcruiser coils and whatnot... also there's a thread called something like "The BJ Spacer/Landcruiser coil thread"... or something of the sort, I believe Cebby started it...?
__________________
- Kevin E. G.
SOLD!!!
'91 4Runner SR5 V6 5spd: CLICK!! FOR SALE NOW!
Proud dad of Kai E. G.!
Keggo is offline
Old 12-19-2005, 06:31 PM   #11 (permalink)
If you go with a bracket lift in the front (btw, dont do it) use one that has completely welded pieces, not the kind that reuses the old crossmember.
Yellow Sub's rig has the that kind and it is a headache to keep aligned.
__________________
~Gabe
birfieldbuster is offline
Old 12-19-2005, 06:42 PM   #12 (permalink)
YeloSub7's Avatar
Send a message via AIM to YeloSub7
Ya it sucks, that's one of the many reasons why I am selling my runner...
__________________
-Jake
1990 4Runner <> 1990 Toyota 4Runner-22RE-5 speed-TG 3" front/4" rear-35" BFG M/T-4.88's-rear LSD-front TruTrac-MC Rear Bumper-TG DOM Sliders-TG Front Bumper
SAS Build-Up
Old Rigs:
'85 4Runner (RIP)
'95 4Runner (sold)
YeloSub7 is offline
Old 01-10-2006, 08:22 AM   #13 (permalink)
hokiruu's Avatar
just out of curiosity why do you advise against a drop bracket on the front? oh and i couldn't have possibly established myself as a noob any more clearly... i meant i actually have 31x10.5 not 11.5. d'oh! I am down with the skinnies and yeah i dont want tons of lift i guess. want to sun 32x10.5 for now so i don't think i'll need 4". with downey hd coils in back and ranked bars in front, will i have the option of fitting 33x10.5"?
hokiruu is offline
Old 01-10-2006, 09:46 AM   #14 (permalink)
tc
tc's Avatar
I have 33x10.50 with NO lift and no rubbing. Make sure you have at least 4.56 gears though (came with 31's from factory)
__________________
tc is offline
Old 07-14-2007, 07:31 PM   #15 (permalink)
gen3_motorsports's Avatar
Im running a 93 4runner SR-5 4x4 IFS and A Superlift 4 1/2 lift kit, 35'' mickey thompson tires 2 3/4 backspace on the wheels no rubbing no limit on what I can clear
The kit includes everything for $2100.00 + install
I did the work my self so I saved $1000.00 on labor
The work can take 2 days
__________________
Gen 3 Motorsports -
93 Toyota 4Runner SR-5
3.0 V6 - No Mods
gen3_motorsports is offline
Old 07-15-2007, 09:30 AM   #16 (permalink)
If you're going to run 33's, save yourself a bunch and install a 2" bl.
That'll work just fine, provide you with all the room that you'll need for 33's, keep your COG low (relatively speaking), provide room to push the tranny and xfer case up and provide room to push the gas tank up, all of which provides more clearance.
Spend the money that you've now saved on armor (bumpers, front and rear, rocker protection, idler arm brace, lower rear a-arm brace, gas tank skid, etc).
Doing this, you'll be set for about anything that you're likely to encounter anytime soon.
Fred
FredTJ is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
cheap 3rd gen susp. lift 20005spd Offroad Tech 19 02-10-2007 06:56 PM
FS: Straight front axle, 6" susp lift, custom built susp, tires wheels kennasbimmer The Classifieds GraveYard 16 05-27-2006 10:44 AM
2Door 2nd Gen vs 4Door lift comparison. cootees 86-95 Trucks & 4Runners 14 01-06-2006 09:54 AM
2nd gen susp. lift Y2Krunner Offroad Tech 2 06-21-2005 02:54 PM
pro comp susp. lift on 2nd Gen. PRO vs. CON tdv 95.5-2004 Tacomas & 96-2002 4Runners 14 12-06-2003 08:32 PM
2009 InternetBrands, Inc.
