Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Noobie Needs Help
I bought a 86 IFS 4Runner. The front control arm bushing are so shot to heck that the local shop will not do a front end alignment until I replace them. Does anyone know where I can find some bushing? I was hoping to find the stiffest ones available like polyurethane or something if it is available so I do not have to buy factory ones. Or if someone knows where to find some affordable after market control arms with bushing that are not too much $$ then that would be great too.
I am a noob to the site and have no idea where to get started. All I know is that I want to get back on the trails ASAP. Thank you everyone for your help. Please someone PM where I can get these bushings. Thanks again! |
| Sponsored Links |
#2 (permalink) |
All these views and not one suggestion? Oh well. I have a few leads and wondering which bushing is the better and stiffer one between the two to use: Polygraphite and Polyurethane
Here are the Polygraphite Ones for sale for $65.00 http://www.p-s-t.com/showproduct.asp...iliateid=10050 Here are the Polyurethane Ones for sale for $38.95 http://www.suspensionconnection.com/...n/18-204T.html I have never heard of this Polygraphite material and need to know if this is better than the common Polyurethane bushings or not. Thanks everyone for your help. ![]() Last edited by Ryan : 07-28-2008 at 05:25 PM. Reason: Forgot to ad the links for everyone to view. |
#3 (permalink) |
http://www.energysuspension.com/pages/toyt1.html
(Make sure you read the footnotes before you order something) |
#4 (permalink) | |
Quote:
__________________
1986 4Runner SR5, Stock 22RE w/5speed, Rear Detroit Locker, Front LSD, 4:88 Gears, 4" Lift, New Mickey Thompson Baja MTZ 33X12.50X15 Tires on the way. Mtn Bike For Sale: http://www.yotatech.com/f110/cannond.../#post50888473 |
#5 (permalink) |
Yes, they are part numbers. I believe you need part numbers 8.3104 (upper bushings) and 8.3105 (lower bushings). You can do a search on google for "energy suspension 8.3104". You'll come up with a couple of places online to order them.
I went to my local performance/speed shop with part numbers off of the ES website and had them order the parts. I got the parts the next day. I didn't want to order the parts online because I didn't know any of the companies listed, so I spent my money locally. |
#6 (permalink) | |
Quote:
Thats great info and I really appreciate it bud. I have bought polyurethane bushings from them before for Honda related builds over the years. I am still looking for a good company that I might be able to just buy control arms from. I have seen these awesome Billet Control Arms offered by www.iconvehicledynamics.com but they do not make them for my 86 4Runner. ![]() And I have seen this full front end suspension kit with longer axles and 2" wider control arms offered by www.downeyoff-road.com but I just can not justify paying $2562.00 for something like this. ![]() ![]() So does anyone know where to get some sweet billet or any nice after market control arms for the first generation 4Runner's?
__________________
1986 4Runner SR5, Stock 22RE w/5speed, Rear Detroit Locker, Front LSD, 4:88 Gears, 4" Lift, New Mickey Thompson Baja MTZ 33X12.50X15 Tires on the way. Mtn Bike For Sale: http://www.yotatech.com/f110/cannond.../#post50888473 Last edited by Ryan : 07-30-2008 at 12:23 AM. Reason: Edit:Typo |
#7 (permalink) |
I still have not found affordable performance after market IFS components. So I have decided to replace most of it with OEM parts until I can get something better. The good news is that I have received the Energy Suspension Polygraphite upper control arm bushings and the lowers are on the way. I also ordered new inner and outer tie rods, and tie rod sleeves. Along with these parts I ordered all upper and lower ball joints, pitman arm, idle arm, all four bump stops, and drop stops. All these parts should be here in the next day or two. I have also ordered new 33" Tires. Today I went out and paid $900 for a new air compressor and air tools, plus a bunch of other related tool goodies for all this. I am sure I will break even doing the work myself+tools, considering what a shop will charge to do all the work in labor. The only thing I have left to figure out is what 4" lift suspension I will use for the front since these ones are well ready to be replaced. Any one have any recommendations for the front 4" lift shocks?
__________________
#8 (permalink) |
following along Ryan -you seem like someone who sets his mind to something and gets it done.Nice to see a guy answer his own questions wish more of us could be of some help.
Sorry I don't know the 1st gens. just a little about 2nds and more about 3rds. good luck with bike sale glad to give you a bump on both
__________________
99 4Runner SR5 4wd 3.4/5 spd Factory Rear Locker/Rear Diff Breather Extension LT265/75/16 Nitto Terra Gs- AR767s Old Man Emu springs- 881 fronts/891 rears Old Man Emu shocks- N91s fronts/ N86 rears All Pro Off Road sliders/ARB "Taco" bumper Redline Tuning hood struts -prop rod now useless! TrueFlow Air Filter fed by airbox deckplate mod Rear wing custom painted in body color (white056) |
#9 (permalink) |
Try DaveZ Off Road Performance
Ask for Dave or John for sales or just check out the site. http://www.davezoffroadperformance.com/contact.html Cheers! J-Rod (530) 622-2148 4603 Enterprise Ct Diamond Springs, CA 95619
__________________
HooKed oN CrawLiN! |
#10 (permalink) |
Thanks guys. I actually did all the work myself and I need to post up some picks. I sand blasted every part and air sprayed every parts to a perfect finish. I also replaces just about every moving part and bushing on the truck now. I had the whole truck torn down to bolts and washer for just over a month and now it is all done. I am just waiting for my custom hydraulic bump stop to show up then I can hit the trails again. I have replaced everything, even all the tie rods, ball joints, and even all new brakes and tires etc. Pics coming soon
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| noobie!!! (lift) | kylerensmeyer | Offroad Tech | 11 | 05-03-2005 04:51 PM |
| I'm a Noobie!! Yeh for Me!! | lilpeanut | Off Topic Talk | 9 | 04-15-2005 09:28 PM |
| Noobie run.... | crash | Off Road Trip Planning, Expeditions, & Trips | 3 | 07-26-2004 05:28 AM |
| noobie here | driveway | Off Topic Talk | 1 | 06-23-2004 09:34 AM |
| Another Noobie! Yay!!! | MudMonkey | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 05-26-2004 03:22 PM |
