VSC lights, ABS lights, No Front Brake Info after Lift
Old Dec 8, 2006 | 02:46 PM
Edrake's Avatar
Thumbs down VSC lights, ABS lights, No Front Brake Info after Lift
I recently got the cornfed 3/2 lift on my 03 4runnner. I had it installed at a shop and as soon as I got in and started it the VSC off, VSC trac, ABS off, and Brake lights came on. The shop told me to take it to a dealership to have the codes reset. The dealership told me that there was no information coming from the front brakes but the sensors were good and they would need to keep it a week to track down the problem. The upside is that it will pull through mud pretty good. Anybody encountered this problem or have a suggestion to track it down without a week in the shop?
Old Dec 8, 2006 | 02:48 PM
Good Times's Avatar
ABS sensors/lines are bad in one or both of the front wheels. Have them replace it as it is a common issue when lifting. This should be done under the warranty as it is a safety issue and only takes 1 day to repair.
Good luck
Jun 1, 2021 01:51 PM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
