Mixing Daystar and Revtek Front Coil Spacers (4th Gen) - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
Old 04-14-2004, 09:19 PM   #1 (permalink)
timber725's Avatar
I just been thinking...
Is it possible to mix the daystar top spacer with the revtek isolator(?) (the one that goes between the top-plate and coil). I guess what I am trying to accomplish is 0.5-1.0 inches of extra lift. 3.5-4.0" lift.
forrunnabilly, I know you got your own custom top spacer. Just thinking if this is something people do...
__________________
'03 4Runner LTD 4WD V8
Revtek 3" Lift w/ NE Spacers | 285-75R16 Firestone Destination MT | 16x8 American Racing AR-23 | BVG Evolution Bike Rack | BVG Adventure Rack w/ Yak Fairing | Husky Liners | Tacoma Skid Plate
| Sylvania Silverstars
timber725 is offline
Sponsored Links
To remove this ad, register today!
Old 04-14-2004, 09:21 PM   #2 (permalink)
Albuquerque Jim's Avatar
If the 4th gen Daystar spacers are the same as the 3rd gen spacers I would say yes it is possible. However, you may experience CV joint failure at that lift height very quickly. Just my $.02.
__________________
'00 SR5, "Highlander"
Dual Cases, Aisin Hubs, E-Lock'd, Cryo'd, Chromo'd, ARB'd, 315's, Sonoran Steel Bumper, Lift & UCA's, 4 Crawl 1" BL, Armored...etc.
F-Toy #081 in progress
Dual Cases, 30 Splines, 5.71's, E-lockers, Hydro-Assist, 37's, DOM Hendrix Chassis, 80Proof, ORS, Sonoran Steel...etc.
Albuquerque Jim is offline
Old 04-14-2004, 10:21 PM   #3 (permalink)
Guest
Send a message via AIM to fourunnabilly
Timber-
I truly feel that you do not want to go any higher than I have in the front. A stocker sits @ 33" from the ground to fender, and I am at just over 39". True, I am running 35" tires, but that still means I have about 4" of lift. My cv angles and boots have held up just fine so far and as I have said before, my angles are still less than 10 degrees, but another issue you may run into is the fact that the higher you go and the bigger the rubber you throw under there, the more difficult a correct alignment is going to become.
I am mixing the revtek spacer with the downey coils in the rear. My custom spacers will be coming out this weekend, and the downeys plus the revteks will remedy the scenario (i hope ). Lance and I are both exploring the coil plus spacer option in the rear. I can get those custom front spacers fabbed for you anytime you want em though. Hope this helps.
Billy
Cant wait to see your ride go up.
fourunnabilly is offline
Old 04-14-2004, 10:55 PM   #4 (permalink)
Good Times's Avatar
Send a message via AIM to Good Times
It is most definitely possible just as Jim has stated. But it is not recommended as you will do more damage than anything else. You'll definitely look good though with a great lift but I think you must worry more about the long term damage that can happen to your 4runner. There are reasons why aftermarket lift developers only make the lift a specific height. It is because they understand the limitation of the truck they're developing, so going beyond what they recommend is not recommended.
Just to let ya know, you can do alot w/ 3" of lift and 285's you know. Getting 4" of lift won't get you that much farther. Keep in mind that when you're on the trail, it's 90% driver skills and 10% truck. I've seen skillful drivers take their truck places I didn't even think it was possible when I saw their truck. So keep that in mind Enjoy your 4runner and learn to appreciate the "stockness" of it so you can be a better driver on the trails!
Good luck!
Good Times is offline
Old 04-15-2004, 06:44 PM   #5 (permalink)
timber725's Avatar
I get mixed messages from GoodTimes and forrunnabilly about the lift height. I see both your points. I have to make the final decision on my own.
__________________
Old 04-15-2004, 09:43 PM   #6 (permalink)
Guest
Quote:
LOL...I guess Lance and I should have told you ahead of time that our true goal was just to confuse you the best we can...
There is honestly no exact or correct answer for this question. I know we are both happy to help you though.
Billy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
daystar 2 1/2" rear coil spacers for sale JM Axles/Suspensions/Tires/Wheels 1 10-01-2006 05:25 PM
Daystar Coil Spacers 4ROMPER 95.5-2004 Tacomas & 96-2002 4Runners 0 03-08-2006 09:55 PM
Daystar 4th gen 1" front lift question 03_4x4Runner 95.5-2004 Tacomas & 96-2002 4Runners 8 11-22-2004 07:51 PM
4th Gen Lift: Daystar front with Revtek rear bocephas70 03+ 4Runner/GX470, & 05+ Tacomas 6 05-13-2004 10:28 AM
Daystar coil spacers........ stretch786 95.5-2004 Tacomas & 96-2002 4Runners 3 06-05-2003 10:23 AM
2009 InternetBrands, Inc.
