HID replacement for '05 4Runner
Old 11-05-2008, 10:40 PM
808sport's Avatar
I am tired of replacing halogen bulbs and want to convert to HID. Is there a kit that is available for my 2005 4Runner Sport? Any advice is appreciated.
Old 11-06-2008, 02:15 AM
Elton's Avatar
your best bet is to replace your headlights with some from a 06 and up as there set up for hid just need to get a hid kit also
Old 11-06-2008, 07:27 PM
Fo_SheeZy's Avatar
www.t4r.org is a better site for 4th. Gen's
A lot of members over there have converted to HID.
Old 11-07-2008, 06:51 AM
Merlin's Avatar
a quick search would yeild some results of HID swaps, bulb types, etc...
the 06+ lights work quite well for the swap since they're projectors, but if you can't swap them, you can do a p&p replacement with the rebased HID bulbs. hardest part was finding a good place to mount the ballasts (well, that and aiming the headlights so you don't blind the @#$@ out of oncoming traffic).
when i get some time i'll probably convert my wife's 06 T4R since she is enamored with the OEM HIDs on her Sienna.
Old 11-07-2008, 06:53 AM
Merlin's Avatar
oh yeah -
imma guessing from the "808" in your s/n that you are somewhere in HI?
if so, you might want to check out RaceFactory down by Cooke St (if you're on O'ahu). they have a pretty good selection.
otherwise, a quick search of this site would probably steer you in the right direction for good online sources.
Old 11-07-2008, 10:56 AM
Jay204's Avatar
Good german made kits ----> http://www.futurevisionhid.com
Old 11-10-2008, 12:25 PM
Telvarin's Avatar
Hid
I replaced my high beams with HID from xenon depot. Left the low beams alone. My rationale was that I needed the light on the highway, not in the city. I mounted the ballasts on the passenger side to the heat shield on my K&N cold air intake. On the other side, I mounted the ballast to the fender support behind the battery.
I have a couple of knocks about this, one is that I don't flash oncoming traffic now (not good for the ballasts to quickly change the voltage repeatedly) and the second is that it takes about 10 seconds for them to come up to full illumination when you first turn them on. Once they have been on for a while, you can dim them for oncoming traffic and then switch back instantly (the ballast stays "warm").
2005 Limited V8
toyota32
07-06-2015 05:42 PM
CJ94yota
07-03-2015 10:14 PM
LSUMatt1514
07-09-2002 03:26 PM
Quick Reply: HID replacement for '05 4Runner
