Do I need to lift/change out the rear if I do a lift? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
Old 01-01-2008, 01:44 PM   #1 (permalink)
On my 2005 Tacoma TRD Offroad ex cab, when I do the 2.5" Camburg lift up front, do I need to do anything to the rear end? The TRD Billsteins have 40,000 on them, so my concern is if I need to swap them out.
Also, has anyone ever dealt with the All Pro Off Road lift kit? It looks a lot more indepth then the Camburg kit, and while its a little more money, I wonder if it wouldn't run better over time.
Need some advice ASAP. There's a 10' snow storm coming the the area this week, so I need new tires and a lift.
tattooo is offline
Sponsored Links
To remove this ad, register today!
Old 01-01-2008, 09:28 PM   #2 (permalink)
Jacket's Avatar
If you lift the front 2.5" and do nothing to the rear, then you'll end up with a pre-runner look (droopy ass). You'll want to do something to the rear suspension to level it out - Add a leaf to your existing springs, or get a new leaf pack that would give you a couple inches in the rear. Changing out the shocks is optional, but you can get more travel and better ride if you upgrade your shocks as well.
__________________
06 Tacoma TRD OR 4x4 V6, TRAC, DAC, OME, ARB, Warn, Demello...
Jacket is offline
Old 01-02-2008, 02:00 AM   #3 (permalink)
ocdropzone's Avatar
Quote:
a lift kit isn't gonna help much with a 10' snow storm
Anyway, yes lift the rear of the truck at the same time. I used a simple Daystar leveling kit, that 'leveled' it too much and ended up using an AAL in the rear till I can get a set of OME Dakars. From what I have read on other forums (not a whole lot of lifted '05+ on Yotatech) both the Camburg and All Pro kits seem to have a decent reputation. Donohue is also a good one.
Just curious if you had Toyota replace your rear springs under the TSB?
__________________
~Robb
'81 Trekker B4Runner Build
'89 Tercel Project POS Gas Saver
TREKKER Forum
LINK TO ONLINE FACTORY SERVICE MANUALS
GOOGLE FOR TOYOTA WEBSITES -pulls from over 80 toyota websites
Toyota Engine, Transmission, Transfer Case Info
Kanyon Crawlers
Wheel Responsibly, Don't screw it up for others...
ocdropzone is online now
Old 01-02-2008, 07:38 AM   #4 (permalink)
Didn't know I could have them replaced.
Anyone care to clue me in on this TSB thing?
tattooo is offline
Old 01-03-2008, 09:47 AM   #5 (permalink)
There's a TSB for weak springs that replaces them. That's why I ordered new ones with my lift although the lift didn't come with new front springs like I expected.
__________________
'06 Tacoma TRD 4wd 4 door short bed, rear locker mod (can use in high range and 2wd now), Skyjacker 3" lift struts with new rear springs and shocks, 285/75-16 BFG All Terrains, more to come.
'08 Yamaha FJR1300 with ABS and power adjustable windshield.
'06 Yamaha Wolverine 450 sport/4wd ATV
'07 Kawasaki Brute Force 750 ATV
William is offline
Old 08-06-2008, 03:19 PM   #6 (permalink)
colsoncj's Avatar
Send a message via AIM to colsoncj
Question, where are some good places to get the OME Darkar springs?
__________________
Cory
Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here
04 Dodge 2500 Cummins - DD/Tow Rig
02 Z06 Corvette - Weekender
94 FZJ80 - Wheelin Rig. Currently on 33"s, plan to go 35"s.
72 Buick GS - i.e. the project that will never get done.
colsoncj is offline
Old 08-06-2008, 07:08 PM   #7 (permalink)
colsoncj's Avatar
nevermind... got it.
__________________
Cory
colsoncj is offline
Old 08-07-2008, 11:15 AM   #8 (permalink)
TexanTaco's Avatar
Quote:
Old thread I know, but my PreRunner doesn't have a droopy ass!
__________________
2004 Tacoma Xtra Cab/PreRunner/SR5/TRD
TexanTaco is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rear lift help Dare44 86-95 Trucks & 4Runners 3 11-06-2007 10:57 PM
Rear lift Anthology Offroad Tech 2 09-12-2006 10:21 AM
sway bar change for only 1" lift? Bennito Offroad Tech 2 10-05-2004 09:50 AM
95 4runner lift (full lift not just rear) gtm130 95.5-2004 Tacomas & 96-2002 4Runners 15 07-04-2004 04:26 PM
Rear Lift Cash4 95.5-2004 Tacomas & 96-2002 4Runners 1 05-06-2004 05:26 PM
2009 InternetBrands, Inc.
