2005 4runner air lift. help please
Old 01-25-2008, 06:36 AM
bnomad's Avatar
I have a 2005 v6 4runner 2wd with a front leveling kit installed. I have now tried to find a air lift for the rear for hauling my trailer or bike hauler. The only one I can find (Air Lift) says it fits my year model but only 4wd. Does anyone know if it will actually fir the 2wd model???
Old 01-25-2008, 07:40 AM
bnomad's Avatar
has anyone tried the Firestone brand? They show to fit 98-08 4runner.
Old 01-25-2008, 01:35 PM
Fossilized
Staff
dropzone's Avatar
Not sure if this will help you much, but AH64ID put them in the back of his old Tacoma (sold it to his dad or dad-in-law) he seemed pretty happy with it:
https://www.yotatech.com/forums/f117...tacoma-113097/
It seemed pretty straight forward, granted the '07 Tacoma has leaf springs and the 4Runner has coils....
Old 01-31-2008, 05:45 AM
bnomad's Avatar
no one has tried the coil air bags on a 4runner? I was also wanting to know if anyone had problems with the ABS, VSC and brake lights coming on after they had a leveling kit installed. The shop I had do it can't figure out what the problem is. They checked the codes but found nothing. WHat could have come loose to turn all those lights on?
Old 01-31-2008, 05:53 AM
ssmathis's Avatar
Check on toyota4runner.org. A couple people there have done them. Here's one link although I don't believe he has this as his current setup.
http://www.toyota-4runner.org/showth...ar+air+springs
Old 01-31-2008, 11:34 AM
bnomad's Avatar
thanks
Old 02-28-2008, 07:22 AM
Colemanfu's Avatar
I haul my KTM with a Versa Hauler - the type that slips into the reciever and hangs across the back. 1st I added some Airlift 1000 then went to an OME 3 in heavy duty spring. The air bag was fine and worked great I just like the look of it a bit taller int he back. When I added the springs I cut 1.5 inches of the spacer for about 4 inches or so of lift in the back.
MO transplant
04-23-2023 11:58 AM
coryc85
09-09-2015 06:24 AM
A2theK
07-12-2015 10:46 AM
jon.r
07-11-2015 03:34 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: 2005 4runner air lift. help please
