yet another CV boot thread
Old 11-16-2012, 02:56 PM
Brendan's Avatar
I'm attempting to replace a torn driver's side inner CV boot. I have the inner boot cleared past the 6-bolt differential connection, but cannot get the outter boot out. The axle between the boots is touching the A-arm and I can't remove it past where the boot is. What am I doing wrong?
edit: nevermind, i got it, but it's a freakin tight fit. i guess i just wasn't swearing enough...
Old 11-16-2012, 06:37 PM
racersg's Avatar
Glad you got it out. It is tight.
Next time it will be easy.
Old 11-16-2012, 09:45 PM
toyota4x4907's Avatar
Disconnect the lower balljoint with the 4 14mm bolts. Makes life easier in and out.
Old 11-17-2012, 10:38 AM
Brendan's Avatar
this is next time. i did it like 10 years ago. i have my torsion bars cranked up a bit now though - does that make a difference? i don't remember it being this hard the first time.
thanks. will that require an alignment?
whats the best technique for removing the studs from the differential flange - just beat the crap out of them? there isn't a lot of room to get a backswing with a hammer.
Old 11-17-2012, 02:26 PM
Brendan's Avatar
got everything back together. the ball joint trick really helped. i wish i would have done that on the removal. i also disconnected the the lower shock mount and stabilizer bar from the control arm. the long bolt/sleeve/bushings connecting the stabilizer bar to the control arm had to be cut off and replaced. the FSM says the torque spec for the bolt is 9 ft-lbs. that seems very light.
all that's left now is a test spin...
icentropy
09-16-2020 02:47 PM
ia02
08-20-2015 11:04 AM
bobjohnson2121
08-18-2015 06:17 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
Quick Reply: yet another CV boot thread
