Xtra cab rear speakers
I've been ˟˟˟˟˟-footing around for a while now about putting speakers in the back of my 93 pickup so I finally just dove right in and figured I'd help people out with the same project. First thing I did was get 2 6.5" kickers from walmart. The mounting was one of my main problems so I went to the junkyard and luckily they had exactly what I needed. The guy had cut 2 pieces of plywood to the size of the opening under the back windows and he covered them with a thin layer of foam and then some upholstery to match the interior. Then I just drilled a few holes and they screwed right in. Took out my seats and some of the paneling to make it easier to move around, then I ran some 16 gauge wire from the speakers to the head. Just a piece of advice: go ahead and vacuum or whatever you have to do to clean everything while its in pieces, you will appreciate it once everything is back together.
i did the same thing not long ago. put some 6.5" pioneers i got for $30 and put them where the cubby compartments were. used thin plywood as the fixture. sounds way better with 4 speakers!!
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
Steezy96yota
07-06-2015 10:00 AM
