Wrong Lower Control Arm Bushings?
Old 05-06-2012, 10:11 AM
Ditch Doc's Avatar
Hey all!
Okay, so I have to torch off my camber adjustment bolts and replace them. Gonna replace the lower control arm bushings while I'm in there. I ordered a set from Advance Auto Parts because they were a lot less expensive than Yota.
They came in the other day. Each bushing was in its own box. Two bushings were smaller than the other two, and seem to be a different design, but the numbers on the boxes were all the same. (two of the boxes were also smaller than the other two).
I called Yota. They are showing all of the bushings as the same part number. Does anyone know which one of these is right?
Thanks!
Doc
Old 05-06-2012, 11:36 AM
wii_tarded's Avatar
The one on the left is the correct bushing. If you don't mind the noise, Energy Suspension sells bushings for 4 control arms for fairly inexpensive. I replaced mine, they creak a little when moving, but should last quite a long time. Only issue with them is you have to re-use the core sleeve which can be a pain to remove.
Edit: the other one looks like it could belong to the upper control arm.
Old 05-07-2012, 08:15 AM
GDR
GDR's Avatar
The one on the right looks like a 2WD LCA bushing.
88sasturbotoy
08-11-2015 01:56 AM
kirkrunner
07-27-2015 07:59 PM
KyleT
07-21-2015 07:54 PM
ksmudrunner99
07-21-2015 05:33 AM
1994toyota
07-17-2015 03:03 AM
Quick Reply: Wrong Lower Control Arm Bushings?
