Wiring in Electric Temp gauge... lighting help
Old 12-12-2011, 05:33 PM
rfcruse's Avatar
I just installed an electric water temp gauge. Having trouble getting the light to work. I tried hooking it up to the cigarette lighter light, but it wouldn't work. Any other suggestions of an easy thing I can tap into so the aftermarket gauge lights up when I switch dash lights on?
Thanks
Old 12-12-2011, 05:45 PM
rworegon's Avatar
Thanks
Stereo illumination wire?
Old 12-12-2011, 06:32 PM
rfcruse's Avatar
The aftermarket stereo I have in there is always on... no dimmer. Just the power wire. So I don't think that would work... thanks though
Old 12-12-2011, 07:46 PM
pholife's Avatar
ac panel light.....
Old 12-13-2011, 07:19 AM
rfcruse's Avatar
Is there any way to get to this wire without removing the stereo, ac panel. i.e. Is it running under the steering wheel somewhere?
Old 12-13-2011, 10:20 PM
PowerstrokeJoe's Avatar
Check the panel where the clock would go. Mine had a plug behind the knockout. I took a test light and found the illumination wire for it and that is what I used for my tach. Its pretty easy to get to as well.
Old 12-13-2011, 11:30 PM
wyoming9's Avatar
Wink
I hooked mine up to the dash light rheostat that way I can dim the gauges with the rest of the lights
just make sure to hook it up to the correct place.
smthwsn357
05-01-2024 07:28 AM
Sleaker
08-26-2020 06:03 AM
gary4runner
09-24-2015 12:53 AM
Johntom240
7
07-13-2015 12:18 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Wiring in Electric Temp gauge... lighting help
