Winch mount for Warn 8000 on 93 pick up
Old 05-23-2007, 05:46 PM
sgarrett415's Avatar
I need to mount a winch to my 93 truck but I dont want to spend a fortune and I dont want to take the time to fabricate. I just want to buy something and bolt it on. My bumper is stock too. I thought about putting on a front receiver and a cradle for the winch. What do you guys think? Thanks for the help!
Old 05-23-2007, 06:06 PM
weakyota91's Avatar
well heres one option it is the absoulute cheapest but only works from the rear unless u mount a hitch to the front of your truck as well. $150.00
http://www.autoanything.com/winches/...0A2017888.aspx
Old 05-23-2007, 06:17 PM
weakyota91's Avatar
Heres the cheapest one i could find that bolts up to the front. made by all-pro
they suggest welding two cross braces for heavy winching but looks like those are your two options for bolt ons and relatively cheap. $399.00
http://www.allprooffroad.com/index.p...sk=view&id=119
Old 05-25-2007, 07:58 PM
weakyota91's Avatar
1979-1995 4RUNNER/PICKUP BUMPERS
Front Bumper Winch Mount - $129
If your looking at building your own front bumper this mount makes a great starting point. This winch mount bolts on to the six factory holes found on 1984-1988 Pickups and 1984-1989 4unners. 1984-1985 body style requires drilling two additional holes in plate. Made from 1/4" plate steel. Two inch receiver tubing is also included. Plate is pre drilled for 5000-9500 low profile winches. Also includes holes for 9.0R Warn competition winch. Designed for use with steel or aluminum hawse fairlead. When building bumper, additional mounting points from bumper to frame are required if used for heavy winching. If using a winch with an integrated solenoid, such as the Warn 9500, trimming of the front plastic grill will be necessary. Unpainted finish.
Heres a cheaper one made by Wab Fab. CLICK LINK BELOW
http://www.wabfab.org/products/bumpers/bumpers.htm
Attached Thumbnails Winch mount for Warn 8000 on 93 pick up-front-winchmount-600.jpg
young buck
18
08-27-2018 02:40 PM
BeMiceElf
10-10-2015 09:40 PM
MTLroadierunner
07-20-2015 03:07 PM
kvanzandt1
07-18-2015 10:15 AM
Odin
07-15-2015 09:28 PM
Quick Reply: Winch mount for Warn 8000 on 93 pick up
