it will turn over but wont start
Old Jun 26, 2008 | 11:14 AM
89yota_mudrunner's Avatar
a while ago i hit a frost heave with my truck and it shut off. i tried starting it back up and it wont start. it will turn over all day long but it wont fire up. i checked the starter cable and all the ingnition wires. does anyone have any ideas?
Old Jun 26, 2008 | 11:19 AM
Ron Helmuth's Avatar
check your airbox connector-electric wiring- undo the connector and verify pins are lining up with the connector.
Happened to me on my 95-2nd gen.
Old Jun 26, 2008 | 09:32 PM
NicCantDecide's Avatar
before you start unplugging stuff and checking wiring I'd suggest checking for spark and fuel first.
Old Jun 27, 2008 | 09:02 AM
there is fuel in it and there is spark on the starter.
Old Jun 27, 2008 | 09:10 AM
Junkers88's Avatar
Spark at the spark plugs would be a good thing to check as well......
Old Jun 27, 2008 | 02:12 PM
abecedarian's Avatar
fusible links and fuses?
Old Jun 27, 2008 | 02:24 PM
fillsrunner4's Avatar
There may be fuel in the tank but is it pumping?
Old Jun 27, 2008 | 02:26 PM
Team420's Avatar
^ beat me to it...lol
Old Jun 27, 2008 | 11:18 PM
Lethal's Avatar
check maf sensor on top of the air cleaner. had same symptoms and fix was "wiggling" connection 5 years ago with out a repeat since.
Old Jun 28, 2008 | 08:29 AM
im kind of thinking now that it is the fuel pump. how would i know for sure?
Old Jul 1, 2008 | 03:26 PM
how would you check if the fuel pump is bad on a truck with fuel injection? maybe im just an idiot...but i really dont know. help...
Old Jul 1, 2008 | 04:18 PM
Jay351's Avatar
Smack the tank with a hammer? Im pretty sure I see a v6 badge in your avatar picture, have you checked compression? When was the t-belt changed?
Old Jul 1, 2008 | 04:54 PM
...or turn the key on and listen for the fuel pump to run...
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
