Will 63 in chevies work w/BJ spacers - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-08-2008, 04:56 PM   #1 (permalink)
If I run 1.5in BJ spacers up front would the chevy swap in the back level it out? Also would the Chevies work with a SAS if I go that route later? Guess I should mention I have a 89 4Runner with a 3.0. Thanks Bryan
bryan is offline
Old 01-08-2008, 04:59 PM   #2 (permalink)
jfreisner's Avatar
You'll have an "Aussie" look, but it should be OK.
Yes, the chev's will work with a SAS.
__________________
Sold the 4Runners....
2000 ECSB z71 Silverado
-Superlift 6-7.5"
-35" Mud Grapplers
-16x10 Weld Super Single II's
-Straight Pipes w/ 5" Tips
-Hypertech
jfreisner is offline
Old 01-08-2008, 05:07 PM   #3 (permalink)
Banned fruitloop
4runnerchevy's Avatar
Springs
Here is a good link, read it before you reply.
http://www.pirate4x4.com/forum/showthread.php?t=20665
4runnerchevy is offline
Old 01-08-2008, 05:07 PM   #4 (permalink)
What is this "Aussie" look you speak of? Thanks Bryan
bryan is offline
Old 01-08-2008, 05:40 PM   #5 (permalink)
TORTIS's Avatar
i just did the chevy swap on my 89 truck. love the ride. pretty easy swap. the magic number for me was ten and one eighth of an inch. that is how far forwards i had to move my front hanger to keep the axle in stock location.
__________________
4 Sale
58'' Sliders $105
67'' Sliders $115
89 Truck X-tra Cab
LCE Timing Chain
31'' Maxxis Buckshot
4.88's built by ZUK(the mind reader)
Aussie Locker Front and Rear
63'' Chevy Springs
Marlin HD Clutch
Bilstein HD Shocks
2.5" Exhaust W/Dynomax Muffler
2-50 Watt Backup Lights
TORTIS is offline
Old 01-08-2008, 05:42 PM   #6 (permalink)
jfreisner's Avatar
Quote:
The"drilling for oil" look.
It will probably give you about 2+" of lift, so it will be OK.
__________________
-Superlift 6-7.5"
-35" Mud Grapplers
-Hypertech
Old 01-08-2008, 07:56 PM   #7 (permalink)
Quote:
Did you have to move the rear hangar any? What have you done to the front suspension on yours? Thanks Bryan.
bryan is offline
Old 01-08-2008, 09:15 PM   #8 (permalink)
frozenSurf's Avatar
drilling for oil? .... I don't get it.
-FroZen
__________________
1986 Hilux Surf 2.4L Turbo Diesel running WVO & B100,
2 1/2" exhaust, boost controller, intercooler, custom cold air intake, custom aluminum roof rack
frozenSurf is offline
Old 01-09-2008, 04:29 AM   #9 (permalink)
TORTIS's Avatar
i used the factory hangers. i cut them off and moved them back about 4" to where the shackle is at 45 degrees. no mods on the front. it raised the rear about 1" above stock level. i hope you have faith in your welding.
__________________
4 Sale
58'' Sliders $105
67'' Sliders $115
89 Truck X-tra Cab
LCE Timing Chain
63'' Chevy Springs
Marlin HD Clutch
Bilstein HD Shocks
TORTIS is offline
Old 01-09-2008, 09:16 AM   #10 (permalink)
ovrrdrive's Avatar
Aussie look? Drilling for oil?
What the feck man....?
The only terms I've seen used are bulldogged for high in the front and raked for high in the back.
__________________
'95 xcab - SOLD
'06 GMC Sierra CCSB 4x4
'03 4runner V8 SR5 completely stock
ovrrdrive is offline
Old 01-09-2008, 09:55 AM   #11 (permalink)
mojo4x420's Avatar
I'm only high in the ass when empty and it doesn't look too bad. When loaded to go camping I sit nice and level and really appreciate the height in the back. I used to bang my rearend constantly w/ my stock saggy springs.
Springs were a bit of work to figure out where to put them. I ended up w/ a shackle that's 7 3/4" eye2eye that gives me about a 40 deg angle using the stock rear hanger. I moved the front spring hanger forward until the center pin of the leaf springs was just in front on center in the wheel well.
Had to figure this out w/ trial and error and some basic trig after the first attempt didn't really work out. Using the length of the leaf springs and the length between the shock mounts, you can figure out roughly how much lift you will get w/ different length shackles. A perfect 45deg would have been about an 8 1/4" long shackle but I didn't want any more lift so I stuck w/ 40deg.
I've attached a spreadsheet for open office that I used to try different length shackles to see how much height I would get. The height isn't absolute height but it lets you experiment a little and compare how much more height you would get w/ different shackles or mount locations.
It also depends on the chevy's. Mine are well used, maybe a newer set would give you more height.
__________________
89 runner - 22re, chevy rear leafs, ball joint spacers, 4.56 gears, 31x10.5xr15
mojo4x420 is offline
Old 01-09-2008, 01:43 PM   #12 (permalink)
sh0kk86's Avatar
for those that dont have oo
__________________
1986 Toyota 22r Short bed Pickup | 33x10.5x15 BFG MT's
nick
sh0kk86 is offline
Old 01-09-2008, 02:09 PM   #13 (permalink)
Bear80's Avatar
Send a message via AIM to Bear80
Here is my write up on the swap, Chevy Spring Swap. I read up on the pirate thread and it helps but I felt there where a few things left out. I tired to make things clear in my write up, such as the way to measure the distances etc. My father runs BJ spacers on his 4runner and my rear setup would be a great match for his front. Just note the shackle lenght and angle. I would recommend buying a Toyota rear hanger and placing it directly behind the stock one and using a similar length shackle to what I run. Also try to find a Toyota truck load leaf, the 4runner load leafs suck and so do the chevy's. You'll also need to think about a double cardon drive shaft.
__________________
1986 Truck - Monster IFS
1997 FZJ80 - Locked, Lifted, Ready
Range Rover Recovery Vehicle
Bear80 is offline
Old 01-09-2008, 02:13 PM   #14 (permalink)
yarosig's Avatar
Maybe if you're smart enough, you would be able to figure it out by yourself.
Read the damn link above and it will clearly tell you Chevy's provide you with about 3" of lift. SO with 1.5" BJ spacers 3" lift in the back. Think hard what that's going to look like.
yarosig is offline
Old 01-09-2008, 02:17 PM   #15 (permalink)
yarosig's Avatar
Quote:
Originally Posted by Bear80 View Post
Here is my write up on the swap, Chevy Spring Swap.You'll also need to think about a double cardon drive shaft.
Why in the world would he need a double cardon shaft with 3" of lift?
It's 3" for god's sake, put some shims in and call it a day.
yarosig is offline
Old 01-09-2008, 02:28 PM   #16 (permalink)
Bear80's Avatar
The shims acutally point the pinion at the t-case, meaing you'll need a double cardon at the t-case end.
__________________
Bear80 is offline
Old 01-09-2008, 02:30 PM   #17 (permalink)
Bear80's Avatar
I have the feeling you're talking out your arse here. Have you done a spring swap and know what setup will give what amount of lift?? The chevy springs can be setup to give anywhere from 2.5-4" of lift. It's not a dead 3" or nothing.
__________________
Bear80 is offline
Old 01-09-2008, 02:33 PM   #18 (permalink)
Bear80's Avatar
Here is a shot of my truck with the front set at the same hight as my father's 4runner on BJ spacers. The rear springs set slightly higher but it's hard to tell in the pic due to driveway slope.
__________________
Bear80 is offline
Old 01-09-2008, 02:52 PM   #19 (permalink)
TORTIS's Avatar
true. i am running three springs which yielded about 1 inch over stock. i kept the stock rear shackles and moves the rear mount about 4". my spring were off a new truck, if you get them off an older truck results will very. if you have an hour, pirate has an on going thread about the 63'' spring swap... it should answer all your questions, and see what mistakes others have made.
__________________
4 Sale
58'' Sliders $105
67'' Sliders $115
89 Truck X-tra Cab
LCE Timing Chain
63'' Chevy Springs
Marlin HD Clutch
Bilstein HD Shocks
TORTIS is offline
Old 01-10-2008, 07:12 PM   #20 (permalink)
yarosig's Avatar
Yes I have done the swap before. Did it on my 1980 which gave me 1" lift because I built an extremely heavy bed in the back. I'm about to do it on my 89 4runner this weekend. I estimate with the hardtop, this setup will net my about 2.5" of lift. I'll have pics for this guy considering I am going to be cranking my bars up 1.5".
yarosig is offline
Old 01-10-2008, 07:48 PM   #21 (permalink)
idayota's Avatar
cant wait to see some pics...good luck this weekend!
__________________
Wherever, Whenever, However...Tread Lightly!
1987 Toyota Pickup build-up thread
idayota is offline
Old 01-11-2008, 01:48 AM   #22 (permalink)
ovrrdrive's Avatar
And good luck with your ride quality after a 1.5" tbar crank...
__________________
'95 xcab - SOLD
Old 01-11-2008, 02:56 PM   #23 (permalink)
mojo4x420's Avatar
Quote:
If you open the actual spread sheet, you can play around with the top three numbers and the rest of the page updates. It doesn't tell you exactly how much lift you get, but it'll tell you relatively how much more lift you'd get w/ a longer shackle or if you moved your shackle mount. Also give you an idea just how much your shackle angle changes just by moving your mounts closer or using a longer shackle.
Once again, the numbers aren't absolute and don't mean anything on their own, only when compared to themselves, which is why there's three columns...
__________________
Old 01-11-2008, 04:32 PM   #24 (permalink)
yarosig's Avatar
Quote:
Sorry can't give a crap had much worse before. I think my back can wait for the SAS this summer, meanwhile I daily drive my 2000 4runner.
yarosig is offline
Old 01-28-2009, 03:04 PM   #25 (permalink)
sr5yota84's Avatar
Send a message via MSN to sr5yota84
So how did this spring swap go? Any pics?
__________________
84 yota truck 31 truxxus m/ts all stock...
sr5yota84 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
how do diff drop spacers work jlohr 95.5-2004 Tacomas & 96-2002 4Runners 10 12-12-2007 09:32 AM
just installed 63 chevies in rear weakyota91 The Fab Shop 3 11-20-2007 04:51 PM
Will these spacers work on a 98 4runner? JM 95.5-2004 Tacomas & 96-2002 4Runners 2 06-07-2006 03:28 PM
aftermarket springs work with spacers? slyang1012 Offroad Tech 3 01-25-2005 12:36 PM
How do balljoint spacers work (and do they work on 4wd)? ianshoots 95.5-2004 Tacomas & 96-2002 4Runners 34 08-14-2004 03:07 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
