Why dont I have this part? and should I ?
Old Apr 30, 2007 | 05:06 PM
swerks's Avatar
Question Why dont I have this part? and should I ?
[/IMG]
When I look up the rear suspension this part always comes up but I dont have one on my 86 SR5 turbo 4Runner. should I????
Old Apr 30, 2007 | 05:56 PM
Elvota's Avatar
Well... I've read your post at least five times and I believe it's possibly one of the most confusing English sentences ever written.
Old Apr 30, 2007 | 05:58 PM
DeathCougar's Avatar
makes sense to me...
That pivot bolt should be for the front of Straight axle trucks.
Old Apr 30, 2007 | 06:01 PM
Sonofmayhem's Avatar
god hates you.
Old Apr 30, 2007 | 06:15 PM
91TPU's Avatar
Originally Posted by Sonofmayhem
god hates you.
hahaha i laughed out loud at this lol...
Old May 1, 2007 | 02:13 AM
swerks's Avatar
when I look up this part in a parts catalog, Its listed as the front part of the rear spring assembely. my truck does not have this. should it or is just a metal inner sleeve for the bushing enough??
Old May 1, 2007 | 09:51 AM
coulda sworn I just said......
What parts catalouge are you looking in? The front pivot bolt on an 86 Truck (assuming thats what you are talking about) is just a regular bolt. The bushing is pressed into the spring, and the sleeve is part of that bushing. The front bolt for rear springs is just a normal bolt.
The bolt you have pictured above is the FRONT pivot bolt for the FRONT springs on STRAIGHT AXLE rigs only. You wont find that part anywhere on your 86 Turbo 4Runner.
Old May 1, 2007 | 10:39 AM
DudeBud's Avatar
lol
Old May 1, 2007 | 10:48 AM
surf4runner's Avatar
answers
so.. NO! & you dont need it either
Old May 1, 2007 | 11:28 AM
he doesn't need THAT bolt, but he will need some kind of bolt to hodl the rear springs in lol. Unless that catalouge says you dont need bolts...
Old May 1, 2007 | 11:42 AM
Jay351's Avatar
˟˟˟˟˟ bolts, duct tape is plenty strong
Old May 1, 2007 | 11:55 AM
OSIRIS's Avatar
bolts! we don't need no stinkin' bolts!
Old May 1, 2007 | 12:30 PM
swerks's Avatar
this is listed as part of the rear leaf spring
Old May 1, 2007 | 12:37 PM
swerks's Avatar
apparently there is a 1 ton hanger pin and a 1/2 ton hanger pin. the one ton is pictured and should still work. the 1/2 ton pin just looks like a bolt.
Old May 1, 2007 | 12:40 PM
ewong's Avatar
Not so sure the 1 ton will work - I think its thicker thant he 1/2 ton one
The 1/2 ton (i.e. your 4Runner) is 18mm
See Marlin Crawler's site for pics
Thats approximately 0.70" btw...
Old May 1, 2007 | 12:43 PM
4Crawler's Avatar
That is the part used for the front spring hanger pin on the front spring of '85 and earlier trucks and on the rear spring on '83 or earlier trucks. On the rear springs of '84 and later trucks, a plain bolt (14mm) is used for the hanger.
Old May 1, 2007 | 12:50 PM
swerks's Avatar
check out this site http://jaw.iinet.net.au/cars/4runner/leafsprings.html
Old May 1, 2007 | 01:12 PM
mudbutt's Avatar
So your 4runner was produced for the Austrailian market? Your Runner doesn't have them cause it is not needed and your stock hardware is all you need.
Old May 1, 2007 | 01:17 PM
4Crawler's Avatar
To the right is the stock rear spring hanger on my '85 which uses a plain bolt:
And the stock front spring hanger (before it was hacked off) which uses the bolt-in pin as pictured above:
Old May 1, 2007 | 01:36 PM
swerks's Avatar
Ok so does anyone have a part # for this bolt/pin
