whining? noise, driver side around 25mph
Old 12-07-2013, 08:08 AM
a51young's Avatar
1990 4runner, manual hubs, 3.0, automatic
I have not been able to figure this out for the life of me. It is hard to describe the noise, it is kind of like a whining noise, or maybe a bad bearing noise. It sounds like it is coming from the area around the alternator/distributor. But it is hard to tell because I can not get it to make the noise unless I am driving.
The alternator seems to spin fine and free without the belt on, no binding that I could feel. I replaced the belt as well, and that seemed to fix the noise for a day, but that could have just been a temperature thing.
I replaced the distributor cover this morning, I noticed it had a couple cracks where the spark plug wires attach. But it is only 9 months old and I don't drive a whole lot. I checked the rotor, it didn't feel like it had movement up and down, just a little side to side.
It seems to happen around 25mph now.
Here are a couple videos of the sound, as best I could do
Any ideas would be great, thanks!
Old 12-07-2013, 08:22 AM
HighLux's Avatar
Not for sure actually. Id pull the front hub off and look at the bearings for sure. First thing Id do. Isnt tire rubbing anything is it?
Old 12-07-2013, 08:32 AM
a51young's Avatar
I'll check that out. The tires should be all clear of everything, they are just 31x1050 on stock wheels. Will checking the bearings be something I can do in a parking lot without special tools? Will I need to take my rotor off to do that?
Old 12-07-2013, 08:42 AM
CJM
CJM's Avatar
Jack truck up on that side, grab wheel at 9 and 3 and pull back and forth. If it seems to have play bearings arent tight in there or are bad.
Old 12-07-2013, 09:46 AM
Stuwy123's Avatar
I don't know out the sound but your speedometer cable is sticky and could use some lube.
Old 12-07-2013, 12:24 PM
a51young's Avatar
I jacked it up, but when I pulled on the tire, it moved the whole vehicle, it was hard to tell if there was play there or not. If there was play there, it is a small amount and I don't know how I'd tell, maybe if I figure out a way to get it off all the tires or something?
Old 12-07-2013, 01:12 PM
Discombobulated's Avatar
I don't think it could be engine related due to the noise stays the same when the rpm's change. I would be looking at front end issues of some sort....
thefishguy77
07-30-2015 10:59 AM
msane99
07-17-2015 10:13 AM
razorman8669
07-12-2015 12:13 PM
crashburnoveride
07-10-2015 06:39 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: whining? noise, driver side around 25mph
