Where to wire in to reverse signal?
Old 10-27-2010, 01:43 PM
Squiddy's Avatar
I am installing a backup camera. System will run when in reverse only, at least for now. With the setup I have, the relay wire is in the cab, and I don't want to run a connection all the way to rear. I know there is a reverse signal wire coming off the trannie somewhere, but can't figure out where (92 4wd pu with 3.0 and auto trans). I also thought about pluggin right into the shifter box, but again not clear where. Any help would be appreciated! And pics of finished product to follow.
Old 10-27-2010, 02:04 PM
Elton's Avatar
the tail light harness should run through the cab could tap into the wire there gonna need a test light
Old 10-27-2010, 02:18 PM
michael1963's Avatar
Is this a wireless system? I had one on my 91 4Runner and all I did was connect the 'reverse' wire right to wiring harness at the rear with the reverse lights. Worked like a charm until I cut the wire when I replaced my rear bumper, now I just turn my head and hope for the best!
Old 10-27-2010, 06:21 PM
pdyebrasil's Avatar
Not sure about your year... When I hooked up my backup camera I used the reverse wire that goes into the gauge cluster. Sorry, not a lot of help, but you don't need to find a wire clear in the back of the truck.
Old 10-27-2010, 06:24 PM
scuba's Avatar
Theres the VSS (or speedo cable) on the back of the Tcase and then the reverse switch on the side of the transmission. Will probably look like this:
I'd find where that enters the cab and go from there...
Shoua
13
05-22-2016 05:19 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
rchavis
07-27-2015 07:41 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Where to wire in to reverse signal?
