Where is the EFI main relay?
I know there is a relay on the passanger front fender under the hood, round style, maked as a EFI relay is there another or a main?
Sorry. 91 4Runner, 3.0, auto,
The EFI main relay is the one of which you speak. Passenger side fender well relay block #2 (the big one). If your looking from the front of the truck at the big fuse block its the second fuse away from the front on the left side of the fuse block, it has a square fuse below and above. There is also a 15 amp blade type fuse, its the farthest one away from u towards the cab on the far right of the same fuse block. theres a big square fuse right above it.
93 yota 4x4 extended cab
new 22re with problems
see thread"22re is toast"
I believe my EFI main relay is behind the passengers side front speaker. Had to pull the glove box and that speaker to get to it. My 4Runner is an 88 but I don't think there is that much difference in the drivetrain and electrical between our years of 4runner.
Posey
Posey
Bourbonblues
12-15-2017 05:43 PM
justdifferentials
14
06-11-2017 08:36 PM
runnermedic
13
09-21-2015 05:20 PM
May-39
09-06-2015 01:05 PM
LJR
09-05-2015 06:02 AM
