where do these go?????
Old Sep 8, 2008 | 04:12 PM
94yota05gto's Avatar
some left over things i have and am not sure where the go. (2 pics of each thing)
thanks in advance Ryan
1st
2nd
3rd
4th
Old Sep 8, 2008 | 04:15 PM
Elvota's Avatar
Pic 1: Oil pressure sender.
fillsrunner4's Avatar
first is an oil pressure sending unit located on the block. Driverside on the 3.0 and 3.4 on the 22re's is on the pass side
This one looks to be the coolant temp sensor usually located on the intake manifold in the back
Looks like a knock sensor which is under the intake manifold on the 3.0 and 3.4 I think its on the side for the 22
Not sure on the bracket. What truck or 4runner do you have? we have no way to tell what were dealing with motor wise and truck wise
Old Sep 8, 2008 | 04:17 PM
DeathCougar's Avatar
1. oil sending unit for vehicles with gauge (pass block, in oil galley)
2. Knock sensor (pass block)
3. Oil sending unit for vehicles with idiot light (pass block, in oil galley)
4. Fuel pump mounting bracket. (pass side block above and behind oil filter)
damn you all beat me to it. I was typing fast!
Nope, thats an oil sender. Coolant senders are mucho smaller
I knew it was for a 22RE
Old Sep 8, 2008 | 04:18 PM
yea i guess you guys need to know what it is lol, its a 94 22re 4x4. if any one has pics of where these go that would be very nice.
Old Sep 8, 2008 | 04:20 PM
If I worked with toyotas all day I may have known
Damns yous
Old Sep 8, 2008 | 04:21 PM
Damns yous
I corrected your mis-diagnosed sensor too
Old Sep 8, 2008 | 04:22 PM
[QUOTE=DeathCougar;50917543]
Whatever
Old Sep 8, 2008 | 04:29 PM
so there are 2 oil sending units? the motor that was in my truck before was an 83 with the old block and head, so i bought a new block and head these parts come out of the old block so im not sure if i even need all of them and i do have a oil pressure gauge. i dont know if that helps any
Old Sep 8, 2008 | 05:44 PM
any pic of where these go????? these are the last things i need to put on before i put the motor in the truck
Old Sep 8, 2008 | 05:53 PM
Only one of those sensors is supposed to be in there. It depends on what you have. Based on the connector in the first pic, thats a 92-95 22RE connector. If you have gauges, you need to use that sensor. If you have an idiot light, you need to use the second sensor.
Old Sep 9, 2008 | 01:30 PM
ok there are two holes in the pass sode of the block that go into the oil valleys, i put both sensors in but are they in the rite spots
also is this where the knock sensor goes???
thanks its been almost a year sence the tear down and was planning a 4.3 swap instead of rebuilding the 22re
