Whats this tube coming out of the valve cover..to the intake?
Old Nov 11, 2007 | 05:23 PM
Tacoma750's Avatar
OK...so on my buick 3.8L There is a rubber hose that goes from the valve cover into the bottom of the air filter. BUT now that im running my custom snorkel, theres no where for that hose to go...Whats that hose for? And what happens if its not connected into anything? My truck seems to run mine.
Old Nov 11, 2007 | 05:36 PM
black diamond's Avatar
it is a pvc, positive crankcase ventilation. it lets the engine blow by go back into the intake. it shouldn't affect performance, i wouldn't block it off, put a breather on it or something. must still vent. snorkel, what kind?
Old Nov 11, 2007 | 05:40 PM
Tacoma750's Avatar
I could out a breather on it, like one of those real small cone filters. You know what I mean? As for a snorkel..this is what I have SO FAR...(excuse the horrible engine bay lol im redoing it soon)
Tacoma750's Avatar
Here you can see the rubber hose to^
Im in the process of building a canister to put around that filter and water proof.
Old Nov 11, 2007 | 05:44 PM
mt_goat's Avatar
If it's no longer connected to the intake, there is no longer the positive part of the ventilation. It is just a vent, not a positive vent. There is a good reason the engineers have a PCV and not just a CV. Without the P the crank case can buildup sludge and the sticky stuff can ruin your engine.
More info here:
http://www.yotarepair.com/Sludge_Zone.html
Old Nov 11, 2007 | 05:45 PM
Tacoma750's Avatar
i dont understand yuor responce....is it bad or good that its disconected lol. BTW this inst atoyota motor. look in my profile
Old Nov 11, 2007 | 06:03 PM
mt_goat's Avatar
Connected to intake=good
disconnected=bad
Old Nov 11, 2007 | 06:04 PM
Tacoma750's Avatar
ah shoot....ok. Wel i guess i could drill a small hole in the bottom of that plenum and tuck it in there? Will that be good enough.
Old Nov 11, 2007 | 06:09 PM
mt_goat's Avatar
Positive ventilation is the same as active ventilation or in other words, forced ventilation. The intake sucks the crank gases out, or forces more out than would otherwise get out on its own. Those gases cause sludge (bad) so you want them out. If you disconnect the hose from the intake you no longer have suction pulling the gases out (bad).
Old Nov 11, 2007 | 06:13 PM
Tacoma750's Avatar
Hm ok...when the hose is just open ended, i can see smoke coming out of it. So your saying when its hooked into the intake, the intake sucks out more smoke and bad stuff?(lamens terms) lol
Old Nov 11, 2007 | 06:14 PM
mt_goat's Avatar
I don't know for sure about that, I need some R&D funds lol.
Old Nov 11, 2007 | 06:15 PM
mt_goat's Avatar
Yep, you got it.
Old Nov 11, 2007 | 06:17 PM
Tacoma750's Avatar
OK...so can you answer my other question now lol? If I drilled a hole in the bottom of the plenum, and plugged the PVC vent into that...would I be ok?
Old Nov 11, 2007 | 06:18 PM
mt_goat's Avatar
See post #11
Old Nov 11, 2007 | 06:19 PM
Tacoma750's Avatar
lol come on man
Old Nov 11, 2007 | 06:21 PM
mt_goat's Avatar
lol come on man
No really, I don't know what/where you mean by "a hole in the bottom of the plenum".
Old Nov 11, 2007 | 06:24 PM
Tacoma750's Avatar
ok...do you know what the plenum is?
Old Nov 11, 2007 | 06:30 PM
WCorbett's Avatar
get a fitting and drill and plug it into the intake tube. try to make it as clean and smooth on the inside as possible.
Old Nov 11, 2007 | 06:33 PM
Tacoma750's Avatar
cant i just drill a hole in the intake tube and put the rubber tube inside?
Old Nov 11, 2007 | 06:36 PM
WCorbett's Avatar
No. it wont seal, it will obstruct the air flow, and is a very lazy way out.just buy a hose fitting and put in in there. They are available at any hardware store.
