What's a code 11 for an '87 22-RE?
I just picked up an '87 22-RE 4runner yesterday and checked for codes by shorting T-E1 and reading the flashes from the CEL indicator. It flashed 11 times with a long pause between the next set of 11 flashes. I've got an '88 FSM for the 22-RE, NOT an '87 FSM, and it doesn't list any code 11. Is there a difference between the 22-RE motors for those 2 years? If so, can anyone tell me what a code 11 is for an '87 22-RE?
Any suggestions?
Troy
Any suggestions?
Troy
Did a quick search for you
https://www.yotatech.com/forums/show...hlight=code+11
http://www.off-road.com/toyota/tech/codes/index.html
Originally Posted by ironroad9c1
yea if it was a code 11 it most likley wouldn't even run with a bad ecu
A/C switch circuit
A/C switch
A/C Amplifire (sic : not sure what this means, but it was in the manual)
TPS circuit
TPS sensor
ECU
Troy
Originally Posted by squishy321
are you sure your not just getting a code 1 meaning everything is normal, it looks kind of like an 11
I get 11 successive blinks and then a long pause, and then it repeats itself et cetera.
Troy
Troy
I've got a code 11 on mine. It's an 86. It also "sputters" badly after getting wet. Not like driving through a pond wet, but like washing it or sitting overnight on a humid night wet. It's always relatively short lived (like it dries out?). If I really rev on it, the hesitation goes away in the higher RPMs and it begins firing on all cylinders and running right. Not sure what it is at this point. Thanksfully it doesn't haveppn that often. I don't even know where to start. I changed the plugs and wires just a little bit ago.
According to the code log, this code is
SWITCH SIGNALS
IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" SIGNAL TO ECU
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
--A/C SWITCH/CIRCUIT
--A/C AMPLIFIER
--TPS/CIRCUIT
--NEUTRAL START SWITCH/CIRCUIT
--ECU
SWITCH SIGNALS
--A/C AMPLIFIER
--TPS/CIRCUIT
--ECU
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
