What would make an engine die instantly?
Old 04-11-2008, 10:31 AM
ozziesironmanoffroad's Avatar
im havin almost the same prob with my honda accord, it will crank and crank, but not catch. sounds like maybe a vacuum problem
Old 04-11-2008, 02:37 PM
Lysmachia's Avatar
Originally Posted by blakegeee
3.0 is NOT interference...
Sounds like you had some good luck on an easy fix. I certainly wouldn't have guessed that! So is it running alright now that you figured that out? As in, that IS definitely what the problem was???
Dunno yet. We haven't busted into it yet. We'll do that tonight. (OK he will. I am baking apple pies)
tc
tc's Avatar
I haven't worked on it yet - hopefully tonight after work
Old 04-11-2008, 06:14 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Have you solder before, tc? Do you know what "tinning" the wires means?
Old 04-11-2008, 06:16 PM
  #25
YodaPala's Avatar
Originally Posted by '884Runner
Don't know how much this helps, but the ECU died in my fiance's car, and it shut off in the middle of the street. She put it in park and it started back up, just ran like crap. Thankfully, she was in front of the Toyota dealership. (BTW, car is a 2007 Corolla S with 30000 miles and have already taken it to the dealership for 3 different repairs; might as well have bought a Chevy
Ha HA HA Good one!!!!
Old 04-11-2008, 06:28 PM
  #26
ChickenLover's Avatar
Originally Posted by tc
Yeah, sounds like it's the O2 sensor wiring. It had gotten too close to the exhaust some time and burned through the insulation, .
I had the same thing happen to my O2 wiring. The EFI fuse blew because of it. Check yours. That's probably why your engine died instantly.
Old 04-11-2008, 08:24 PM
  #27
tc
tc's Avatar
Yeah, I've soldered before.... heat the wire, not the solder, let it flow into the wires.
So, it was the O2 sensor wires. Insulation was melted through (again). Cut out the bad part, soldered it back, heat shrink, tape, foil, and zip tied the crap out of it (last time I just taped it all up) ... hopefully it stays fixed this time!
Old 04-12-2008, 04:14 AM
  #28
thook's Avatar
Okay......I was just asking. Wanted you to see good results.
I soldered the TPS and ECT sensors on my 3.0 last year (a little "crash" course in soldering....wrecked the vehicle) and that's how I learned to do it. Worked very well.
If it's ever a concern, most electrical supply places have this rubbery, goo stuff...forget what it's called...that you apply to the splice to waterproof it. I've used it whenever I've had to make underground splices for electrical feed lines to the house.
Old 04-14-2008, 10:32 AM
  #29
tc
tc's Avatar
So, drove the hell out of it this weekend with no issues ... seems that the O2 sensor wire was it!
I'm interested to see if that was the cause of my pretty horrific gas mileage recently too...
Old 04-14-2008, 11:16 AM
  #30
Staff
DeathCougar's Avatar
did you try the fuel filter?
Glad ya got it all fixed up!
Old 04-14-2008, 04:32 PM
  #31
tc
tc's Avatar
Just did the fuel filter not too long ago ... won't be doing THAT for a while!
Old 04-14-2008, 04:36 PM
  #32
Staff
I know. I just figured thats what all the "guessers" suggest first and I hadn't seen it suggested (and no, you aren't one of the guessers heh)
Old 04-16-2008, 03:21 AM
  #33
Lysmachia's Avatar
It's so nice to have Ron (as in Burgundy) back in the game!!! Thanks for all the good help all!
Old 04-17-2008, 09:01 PM
  #34
tc
tc's Avatar
Got 19.9 MPG on my last tank! That's almost double what I was getting over the last several tanks!
bigjstang
08-25-2021 12:41 AM
steve miller
10-10-2015 01:40 AM
TURBOrunnerNM
07-22-2015 11:01 AM
God's Bounty Hunter
07-08-2015 12:54 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: What would make an engine die instantly?
