what vaccum hoses and valves can i remove from my 22re?
Old 03-14-2007, 08:13 AM
4Crawler's Avatar
Read all about it's operation:
http://autoshop101.com/forms/h62.pdf
But the vacuum line is used to "suck" the gasoline fumes out of the cannister into the intake, and since it is gas vapors, it can go in any time. It is under a switched port in the TB so that fumes are only used at certain throttle positions. The line down to the frame is what lets in fresh air to pull the fumes out of the charcoal. If not present, the vacuum in the cannsiter would suck gasoline (liquid) from the tank (kind of like sucking on a straw). The cannister purge line on my '85 is 3mm (labelled P on the TB).
Old 07-04-2007, 07:19 PM
lonestar's Avatar
THAT WAS THE MOST INTENSE POST I'VE EVER READ
But very very very helpful
lonestar
Old 07-08-2007, 05:02 PM
854x4's Avatar
Will removing the FPR VSV mess with smog at all? What does the power steering VSV do?
Old 07-08-2007, 05:11 PM
Bigblock's Avatar
Tell him how to do it ;He can do nothing but help that old truck.
Old 07-08-2007, 05:40 PM
  #25
4Crawler's Avatar
Nope, engine vacuum will still go to the FPR to regulate it per the engine load. The VSV only helps with some obscure hot start problem that I have never observed in ~5 yrs. w/o the VSV. Power steering VSV just bumps idle speed when steering to keep the engine from bogging down. I've not had that for 8+ years and if needed, I can blip the throttle for a little steering boost at idle.
Old 07-08-2007, 07:43 PM
  #26
854x4's Avatar
Thanks 4Crawler
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
Poncho0206
07-10-2015 06:21 PM
ItsJustD
07-07-2015 07:49 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: what vaccum hoses and valves can i remove from my 22re?
