what is this VAC TUBE...
Old 02-12-2007, 03:57 PM
AUYota's Avatar
It's pluged up because if it isn't it runs real rough...
Where does it go to?
Old 02-12-2007, 04:08 PM
AndYota's Avatar
http://personal.utulsa.edu/~nathan-b...74layoutan.pdf
That one (I think) goes to one of the 3 VSVs mounted on the PS wheelwell. Check the link, it might help.
Old 02-12-2007, 05:08 PM
chrishf12's Avatar
its either the VSVs or your egr vac hose. In your picture ur egr isnt even hooked up!
Old 02-12-2007, 06:17 PM
AUYota's Avatar
OK now I feel stupid... That tube goes to where it says it goes in the scamatic. trouble is I had some tube backwards but I fixed it. Basically the VCV for the EGR was going to the charcoal canister not to the vac source. So I incorrectly assumed that the EGR valve was blown when in fact it's VCV wasn't getting vac, so I disconnected the EGR valve. I've since reconnected it.
Here is the problem. Look at the scamatic. You'll see that the charc canister has a tube that goes to the TVV for EVAP (what in the world is that!) UNDER the pelum. I wiggled my fingers all over that $%^&* and can't find it!
SOMEONE HELP!
Old 02-13-2007, 05:39 AM
AUYota's Avatar
Anyone knoew where the TVV for EVAP is? If you look at the scamatic in the second post you'll see it located below the pelum, but I couldn't find it. It's the tube that goes to the charc canister.
Old 02-13-2007, 01:37 PM
WillRadford's Avatar
In the 1991 4Runner 3.0 that I bought a month ago I don't have any wires going to my EGR either, buy my 94 does have a wire going into the EGR. Is it normal for there to not be a wire going into the EGR valve for the older 3.0s?
Old 02-13-2007, 01:49 PM
AUYota's Avatar
Once the EGR starts to stick your gas milage plumets. Disconnecting the EGR saves a little of that lost MPG.
That said does anyone know where the TVV for EVAP is noted on this scamatic somewhere under the plenum... I can't find it!
Old 02-13-2007, 04:43 PM
AUYota's Avatar
ok... I found the TVV for EVAP located under the plenum. Turns out that the nipple to take a tube to the charc. canister is broken off. Is there any performance detriment from not having the EVAP properly installed?
coryc85
12-05-2015 08:42 AM
sanctfy
09-13-2015 06:33 PM
Valvoman
09-06-2015 07:24 PM
May-39
09-06-2015 01:05 PM
tomczaksdiesel
07-26-2015 10:35 PM
Quick Reply: what is this VAC TUBE...
