What to use for air injection manifold gasket?
Old 06-27-2009, 02:44 PM
Karlton's Avatar
I'm rebuilding my '94 22re and purchased a "full gasket kit" and it did not come with 2 gaskets for the "No.1 Secondary Air Injection Manifold" which runs from the No.2 Secondary exhaust, around the back of the cylinder head, to the intake side and connects to the PAIR Valve.
Here's a link to a diagram; http://personal.utulsa.edu/~nathan-b.../7cylinder.pdf
The original gaskets are made of the same metallic gasket material as the exhaust manifold gasket. I still have them but they a trashed. I've been looking for them all over and can't find any. I haven't seen any exhaust gasket sets that include them either.
Would another type of gasket material be suitable? Or maybe re-using the originals and slathering them in some sort of sealant?
Any tips would be greatly appreciated.
Old 06-27-2009, 09:33 PM
854x4's Avatar
I remember reading that these gaskets are hard to find might be a dealer item? Permatex makes some stuff called ultra copper if you cant find the gaskets.
Old 06-27-2009, 09:51 PM
scuba's Avatar
Did you try the dealer ?
if not your part numbers are listed in this pic.
Even highlighted too.
Old 06-27-2009, 11:32 PM
854x4's Avatar
Hey Scuba, what program is that?
Old 06-28-2009, 04:29 AM
Teuf's Avatar
get a sheet of exhaust gasket material, metallic kind, then cut to size, i had same prob. good luck
Old 06-28-2009, 05:28 AM
Just Learning's Avatar
i would go to the dealer
Old 06-29-2009, 11:30 AM
Karlton's Avatar
Thanks for all the replies and the parts numbers. This site is a huge help!
My nearest dealer is very expensive and seems to never have what I'm looking for when i need it. Amazingly they had two in stock.
Phew!
the1998sr5
15
07-14-2020 08:35 PM
tj884Rdlx
08-28-2015 12:04 PM
yourrealdad
07-21-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: What to use for air injection manifold gasket?
