What is my rear end gear ratio?
Hi all,
I have a 97 4runner v6 4x4 and need help with my final rear end gear ratio. The tag on the door says A/TM A03A/ A340F
One source tells me a 4.10.
Please advise
Thanks,
Please advise
Thanks,
One way to check is to jack up the back end and and check how many times your tire turns in relation to your drive shaft.
If its 4.10 then your drive shaft will turn a little over 4 turns to your one wheel turn.
Turn your a larger number of times to get it more accurate. 20 wheel turns instead of 10. That kinda thing.
you can call the dealership with your vin number and axel code and they might be able to tell you. You can also pull the drive shaft off the third mdmber, and there will be a color painted on the end, that will tell you too. I have no idea what color is what, but I am sure you could find it with a search.
Not to steal the thread but while we are on the subject of rear gears. How do you go about measuring the rear gear like as if you have it out and it is in your hands?
icentropy
07-11-2015 07:21 AM
icentropy
07-09-2015 02:12 PM
Jnkml
07-06-2015 01:20 PM
