what to lift
Old 02-19-2009, 02:56 PM
mrtrd103's Avatar
what to lift
i want to lift my 94 4runner. i talked yo some guys on here about a body lift and its just to mich work to do. is there an easy way to lift the truck with just rear coil spacers or longer springs for the back and some sort of spacer for the front. i read some things about bj spacers and ball joint lifts. how are those and how much would it all be. this would just be for looks and once and a while off road.
Old 02-19-2009, 03:02 PM
94Runner4x4's Avatar
Search for second gen lift guide and you should find anything you need to know about lifting a 94.
Old 02-19-2009, 03:19 PM
bigt's Avatar
body lift is cheaper and easyier toinstall then fron bj or balljoint spacers.. the rear yeah a coil spacer is the cheapest.. but you can fit 31s or 32s stock... so if you ust want a lift id just do a body lift... put 33s and call it a day!
bodylift is about 120 bucks ,,, thats how much just the bj spacers are... coil spring spacer are another hundred say
Old 02-19-2009, 04:48 PM
abecedarian's Avatar
Are you trying to 'level' your truck or do you really want a lift?
Old 02-19-2009, 04:49 PM
There's a pinned 'guide' for 2nd gen lifts: https://www.yotatech.com/forums/f116...-guide-155339/
Old 02-19-2009, 07:15 PM
Yea that's what I was thinking of, I couldn't think of what to call it and didn't have the time to go search for it myself.
Old 02-20-2009, 03:01 AM
mrtrd103's Avatar
thanks guys but if i do a body lift isn't there a lot of extensions to do and things to move. also i thought u cant use a body lift for an automatic. but if u guys say its easy ill have to do the body if is under 200
Old 02-22-2009, 10:51 AM
mrtrd103's Avatar
ok i know a body lift is cheaper but. how hard is it to install and i have an automatic. i was thinking about ordering a 3 inch body lift from performance accessories this summer
Old 02-22-2009, 10:57 AM
4banginRunner's Avatar
when i bought my old 90 4runner it had a 3" BL on it at it was an auto, and when i got my 87 4Runner automatic it had a 3" BL on it as well. The kit just includes drop brackets for the shift linkage.
Old 02-22-2009, 10:59 AM
Not hard at all, hardest part is loosening the old body mount bolts, espicaly if you live in the rust belt. New bushings wouldn't be a bad idea while your there anyway.
Old 02-22-2009, 11:02 AM
mrtrd103's Avatar
ok is it time consuming to do and what happened if a bolt breaks does the kit comes with new ones and how hard is it to do. will i be able to keep the front bumper i seen people do the lift and take the bumper off
Old 02-22-2009, 11:08 AM
check here too- http://4crawler.com/4x4/ForSale/Body...html#ATbracket
Old 02-22-2009, 11:16 AM
dark_fairytales's Avatar
this is that you will need for your auto-tranny. http://4crawler.com/4x4/ForSale/Body...html#ATbracket
you can also find lots of info. about body lifts on that site as well, 4crawler.com is an excellent source for yota info.
Old 02-22-2009, 03:21 PM
Not really time consuming, I took one off my 87 in about 2 Hours....bolts were a pain. I put a 2" on my 79 Pickup in under a hour.
Kit probably comes with bolts, if not...hardware store and $10 will get ya what you need. (Grade 8 o course)
Kit comes with bumper brackets for the front, rear bumper is already attached to the body.
Old 02-23-2009, 12:32 PM
mrtrd103's Avatar
alright sweet i gonna go see my parts guy tomorrow for price and ill probably order and do it dis summer
thanks for all the help
Old 02-23-2009, 12:44 PM
904_runner's Avatar
Where are you ordering from?
Ive heard nothing but good from ordering through 4crawler.
Dparr2ndgen
09-08-2015 01:06 PM
justdifferentials
09-05-2015 06:52 PM
joeynational
09-05-2015 01:54 PM
matthew138
09-03-2015 08:21 AM
Ryall
09-02-2015 06:48 AM
Quick Reply: what to lift
