What Large Sockets For Toyota Work?
Old 02-21-2013, 06:19 PM
wrenchtech's Avatar
I stumbled on a good deal on 3/4" drive breaker bar today. Now I want to know what size sockets I should look for. On the small end I see that I cold find a 19mm. Maybe I'll try to go as low as 17mm. What other sizes would be useful? I know 3/4" drive sounds like overkill, but when you live in the rust belt it comes in handy.
Old 02-21-2013, 06:44 PM
Co_94_PU's Avatar
I must be somewhere near the rust belt I though 1/2" or bigger was standard kit. The lug wrench I use for torsion bars is 11/16th IIRC so yes to a 17mm.
Hub nuts(2wd&4wd differ?), diff drain plugs, strut bars, cab and bed mounts, frame cross brace, rear engine/tranny mount, spring mounts, diff u-bolts.
Those are all the ones that come to mind off hand but I don't have the sizes handy. Please if someone could fill them do. Thank you
Old 02-21-2013, 06:48 PM
Roark's Avatar
I know 17 is used on the transmission, and I think either 19 or 21 is used on the crossmember bolts. And then a 21 or so on crankshaft bolt. You know, I'd just invest in a high quality set of 16 or 17+.. It's always useful to have that bolt when you need it
Old 02-21-2013, 06:49 PM
snobdds's Avatar
19 -24mm, 30mm. That will cover lug nuts, shock nuts, Front/Rear Diffs, TC, tranny, Pinion nut, suspension castle nuts, etc.
Or...
Just get 1 3/4 to 1/2 adapter and use your old socket set.
Staff
DeathCougar's Avatar
17mm, 19mm, 21mm (Lugnuts), 22mm, 24mm, some 27mm and 30mm stuff. 54mm socket for front spindle nuts.
Fwiw, the ONLY thing on a Toyota that is 21mm is the LugNuts
Old 02-21-2013, 06:53 PM
Roark's Avatar
Or...
I've broken a few craftsman adapters on bigger torqued bolts..just a warning, I suppose.
Old 02-21-2013, 09:22 PM
wrenchtech's Avatar
Well good! 17 and 19 are on the way, and I've already got one of those 54mm stamped metal spindle nut sockets.
gillesdetrail
11-19-2019 12:56 PM
voiddweller
19
05-02-2016 09:10 PM
gog1968
06-22-2015 05:55 AM
AustinTaco
06-21-2015 09:54 AM
Quick Reply: What Large Sockets For Toyota Work?
