what the hell?
Old Sep 8, 2008 | 12:33 PM
camo31_10.50's Avatar
what the hell?
i feel stupid asking this....but where's the fuel filter on my 1986 toyota 4x4 22R x-tra cab...i've looked everywhere between the tank and the carb...so im guessing its in tank right?...becuase if not..then there is no filter on my truck...wtf
Old Sep 8, 2008 | 12:38 PM
abecedarian's Avatar
if it's carb'd, the fuel filter should be near the gas tank, or on the right fender well.
Old Sep 8, 2008 | 12:39 PM
Team420's Avatar
Not positive.... but I read it is under the plenum? against the firewall? From what I have read...its a p.i.t.a. to get to.
Old Sep 8, 2008 | 12:40 PM
true for a 22re (injected), but not for 22r (carb'd)
Old Sep 8, 2008 | 12:43 PM
kramykram's Avatar
I know on my old 85 X-Cab PU 22R it was mounted on the frame between the tank and engine bay. Man it's been a long time since I have thought about that.
Old Sep 8, 2008 | 12:44 PM
netgodsrdn2's Avatar
On my 86 2wd with a 22R it was on the inside edge of the frame rail in front of the gas tank.
Old Sep 8, 2008 | 12:47 PM
not in any of those places....even had a mechanic that knows a thing or two try to find it and he couldnt find it...so we're still lost..but im gonna double check everywhere later tonight. thanks for the quick replies
Old Sep 8, 2008 | 01:01 PM
no disrespect intended, but... are you sure it's a 22r and not a 22re?
Old Sep 8, 2008 | 06:20 PM
Yopar's Avatar
If it's the 22RE (injected), then the fuel filter is under the intake manifold, mounted to the block and is a pita to get to... that's why I have mine NOT bolted to the block, and resting on the fender NEXT to the intake manifold...the stock fuel lines allow this and it's been fine so far...it's very easy to change now!
Old Sep 8, 2008 | 06:33 PM
DeathCougar's Avatar
Fuel filters are overrated
But, if its stock, it should be mounted just above the frame about the middle of the fuel tank.
Old Sep 8, 2008 | 06:46 PM
alliekay's Avatar
IIRC. It is obstructed by a cross member. But it is on the frame rail. Meaning, you can feel it but not see it unless you drop the cross member.
Transfer case I think. It has been a long time.
Old Sep 8, 2008 | 06:56 PM
You can't drop the crossmembers in the rear without cutting them off the frame Or are you talking about the fuel tank straps/crossmembers?
Old Sep 8, 2008 | 07:21 PM
drew303's Avatar
its infront of the fuel door betweem the tank and the rail inbetween the two bed mounts (on a stndrd cab) but still same place on the xtra cab
for all 22r model toyota pickups. 22re is in the engine bay
To remove the fuel filter completely would require hooking the hoses together, i don tknow why anyone would do that
Old Sep 8, 2008 | 07:30 PM
drew303's Avatar
this is the best photo i could find
the bracket is mounted to the second mount (away from the cab) on my rig. I dont use the bracket anymore I used zip ties on the fuel lines to hold everything in place
Old Sep 8, 2008 | 07:33 PM
alrighty guys..what the hell..im getting 12 different answers...which is right...YES it is a 22r...carb'd...i know my toyota pickup motors...could it be the fuel pump?...DOES ANYBODY MAKE AN IN TANK FILTER for our trucks...could some dumbass have put one in the tank?...i know its not in tank stock..but its no where else that we've been able to find...so..we have followed the fuel lines all around..from tank to carb and back..no filter...it has an inline filter on it now...im gonna check a few more places...if i dont find it..im probably gonna drop the tank...lol..but thats a pita..so dont let me do it..tell me where it is..lol
Old Sep 8, 2008 | 07:45 PM
Myself, Drew, and Abe's first answer were all correct.
Old Sep 8, 2008 | 07:48 PM
ozziesironmanoffroad's Avatar
on the 22re its a PITA, when i did mine i had to remove the intake for simplicities sake.... and im a poet and i dunevenknowit
Old Sep 8, 2008 | 08:04 PM
JamesD's Avatar
Take a picture. It should be near the filler neck. It is possible some redneck bypassed it.
James
Old Sep 8, 2008 | 08:12 PM
iamsuperbleeder's Avatar
Originally Posted by JamesD
...It is possible some redneck bypassed it...
hey, wuts that pose to mean...
Old Sep 8, 2008 | 08:35 PM
ok..yall were right...aparently we didnt look hard enough..its right where yall said it was...right there in the pic too...so...took it off...sure enough its clogged...so i cut it open..and its got rusty gas in it...BUT...the gas coming out of the filter was clear..just like it should be..but it was nasty...so since i already put another filter under the hood less than an hr ago..i just bypassed the one by the tank until tomorrow...so..as of now..the fuel problem is fixed..no more spitting and sputtering ad dying..BUT...new problem...i cant even get it to speed up past 55...its like i have lost ALOT of power...i have an after market exhaust on it right now...its a thrush turbo muffler with a turndown...no cat...the muffler is where the cat was...and its been fine...until one day i was getting on the interstate...and i was in second gear doin about 30mph...and all i hear is..POP...then a really loud noise..so i figured i cracked my exhaust manifold..well turns out...our mechanic forgot 3 bolts when he put the manifold back on..so that made me lose power..and i had a 4ft flame shooting out the tailpipe as i let off the gas...(all my friends loved it.LOL...they were drunk..lol)...so i get back to the house the next day...figure out the problem...put a bolt in it..problem solved..i thought....now it runs fine around town..PLENTY of power..but once i lay on it..and i start getting in the higher level rpm's...i can here it start leaking up there from the other 2 holes...so my question is...could that be where my power loss is coming from?...i drive 10 miles to ICTC EVERY morning...and my class starts at 8..and i leave my house at 7:40..and get breakfast at a gas station..so i get there at about 7:55...well..cant do that goin only 55 mph...im also getting horrible gas mileage since i filled up last..(about last thursday or friday)...which is when all this fuel stuff and everything started going wrong...i work everyday..so i need the vehicle to be in pretty decent running condition..im used to running about 75 on the interstate no problem..now i can barely get 55...big problem..help my out!!!
