What is the gas tank size for 1st gen 4runners?
Old 06-22-2007, 12:45 PM
dijlop's Avatar
mine doesnt have one. a '94 pickup. course i also think ive got a 12 gallon tank. cause ive rolled it into a station b4 and filled up with 11.978 gallons. course thats after the nozzle cut out and i just kept goin till i hit an even number. lol.
Old 06-22-2007, 12:52 PM
eightnine's Avatar
Originally Posted by DudeBud
ok.. maybe its a newer cluster thing, but then again my 88 standard cluster had non.
nvm man sorry i guess i was wrong. When i put it on the ON position all the lights go on except the Gas light. It is supposed to be imbetween the "CHARGE" and the "BRAKE" warning lights. It is yellow and says FUEL. Here is the pic, its off my cell phone so it looks crappy.
edit: BTW a couple months ago i thought i had no light either. It was because i was too scared to let it go to low and then one time i felt brave and waited until it got REALLY low, then it came on for a second and then turned off until it eventually just stayed on all the time. The little meter has to go about 5 centimeters below the line the light to turn on.
Old 06-22-2007, 01:25 PM
91muddog's Avatar
Originally Posted by 89-4Runner
should I run it out of gas to see if my low fuel light comes on? (JK) I've got the SR5 guages, so I would assume I should have the light too, no? anyone have this dash without a low fuel light?
you should be able to see if in direct sunlight to know if its there or not.
Old 06-22-2007, 01:31 PM
eightnine's Avatar
yeah that also works
Old 06-22-2007, 03:44 PM
  #25
89-4Runner's Avatar
Originally Posted by netwt12
both 14 & 17 gallon tanks were offered. they have different pump hanger assemblys and different sending units. the pumps iirc are the same or can easily be modified to work.
so differnet size tanks dictate whether or not there is a low fuel light? Tried to look at the dash for it (not in direct sunlight) but couldn't tell... anyone with the grid pattern guage panel from a 89 got a light?
Old 06-22-2007, 05:52 PM
  #26
Greg_Canada's Avatar
Did anyone even read my post? ALL fuel tanks are the same size, it's US or IMPERIAL gallons that makes teh difference, they are all 65Litres.... lets just stick to metric...
Old 06-22-2007, 08:08 PM
  #27
DEEPRUNNER88's Avatar
Ive got an 88 sr5 and the cluster does have a fuel light. Mine turns on and i wont go past 20 miles. If im lucky Ill let it turn on twice then get some fuel.
Old 06-22-2007, 10:22 PM
  #28
eightnine's Avatar
x24886
Old 06-23-2007, 05:25 AM
  #29
ewong's Avatar
There are TWO sizes for the Gen1 4Runner tanks.
Here's how to tell which one you have
http://www.pirate4x4.com/forum/showt...t=4runner+tank
Old 07-19-2007, 05:04 PM
  #30
My99's Avatar
Anyone measure this on a 4Runner? The distance from the seam to the bottom of the tank varies depending on where you take the measurement from (on the passenger's side). This is complicated by the presence of the skid plate/shield below the tank that wraps up around the bottom of it. I've never seen the gas light on my truck come on. The gauge shows empty and I only put about 12 ish gallons in it. Trying to find out if I have 2 gallons or 5 gallons left.
Old 07-19-2007, 10:42 PM
  #31
Diesel_Freak's Avatar
My 89 Gen 1(5spd 22RE) has a Fuel light. Standard cluster, no tach...
I guess I have the 17gal tank cause I got it to take 16.2 Gal once...
Interesting that there are 14 and 17 gal tanks I can't imagine wanting a smaller tank.
Dave
Old 07-20-2007, 01:11 AM
  #32
4bytruckin's Avatar
in the owners manual it says 2 tanks were offered the 14 and the 17. sorry canadian thats standard gallons for both. it also gives different liters for both. but since i'm in america i don't remeber metric
06-01-2021 01:51 PM
Whatever123
09-30-2015 12:12 AM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: What is the gas tank size for 1st gen 4runners?
