What is this air intake hose?
Old 07-02-2011, 10:14 AM
Culpeper's Avatar
The hose the picture is pointing at is making a whining noise when I hit the throttle. Does anybody know what this hose is for? Thanks
Old 07-02-2011, 10:18 AM
MudHippy's Avatar
Funny you should mention that. I was just talking about it. PCV valve hose. That's not the factory pre-bent hose, so it's been replaced obviously.
Whining? You mean hissing? Is it leaking you suppose?
Old 07-02-2011, 10:32 AM
Culpeper's Avatar
No, its not leaking and seems to be holding pressure or feels like it is supported inside the hose. Now I know why it makes a clicking sound when I squeeze it. The whining noise is low pitch. Not like a squealing drive belt nor hissing. Much lower tone like a moan. Made me think at first it was the water pump but turned out to be this hose or something along its line.
Old 07-02-2011, 10:42 AM
MudHippy's Avatar
There shouldn't be anything inside the hose, or positive pressure for that matter. I'd start by removing it and finding out what that is. BTW it should have some sort of spring type hose clamp on it at both ends too. I notice the one end that I can see is missing the clamp. You can get those at a hardware or auto parts joint, but I replaced mine with small adjustable clamps.
Old 07-02-2011, 10:52 AM
Culpeper's Avatar
Ok, I'll check. Seems like the hose is a POS aftermarket thing. It is probably the hose that is making the noise but I'll post something when I find out for sure. Thanks for the quick responses.
the1998sr5
15
07-14-2020 08:35 PM
RatOmeter
10-22-2015 03:17 PM
Alex Bessinger
08-31-2015 09:17 AM
gmonnie123
07-26-2015 02:44 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: What is this air intake hose?
