Weird bogging while engaging clutch
Old 10-26-2007, 06:16 PM
Guardian_Saint's Avatar
Recently after the timing replacement I am having this bogging issue while trying to go on 1st gear but is very noticeable at 2nd gear, alittle bit on 3rd gear and none at 4th & 5th gear. I have everything in correctly order and timing it at 10 degree, spark plug wire 1 year ago, chenge spark plugs 5 months ago. When it is in neutral it rev at no problem w/o bogging like in gear. I know it doesn't look normal cause I know the normal for a clutch to bog down a bit but not like this, it felt like the piston had stop for 3 second, causing it to died then back to live again, after that it rev fine. Whats the ordeal of this, I'm thinking TPS adjustment needed? thanks in advance.
Old 10-26-2007, 06:29 PM
n4ynu1010's Avatar
I think that would be a good place to start if everything else is good , you have the walkthrough for that ?
Old 10-26-2007, 06:50 PM
I am searching for it, found one that may guide me through it, I am just giong to do it the way he done on his, adjust it with the yellow mark indicated on his picture shown on his thread, thanks n4ynu1010, I will start from there.
Old 10-26-2007, 06:53 PM
n4ynu1010's Avatar
Tps
Originally Posted by Guardian_Saint
I searching for it, found one that may guide me through it, I am just giong to do it the way he done on his, adjust it with the yellow mark indicated on his picture shown on his thread, thanks n4ynu1010, I will start from there.
Here is a good walkthrough :
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
and here is the one from FSM :
http://personal.utulsa.edu/~nathan-b...93throttle.pdf
Daenerysdad
10-01-2015 07:33 PM
93toyoguy
3.4 Swaps
10
09-18-2015 04:16 PM
May-39
09-06-2015 01:05 PM
Nick Berg
09-03-2015 04:36 AM
Quick Reply: Weird bogging while engaging clutch
