Waterfall in my dash
Old 01-04-2013, 02:42 PM
Rickstwowheels's Avatar
In my 1987 model 4runner, at higher RPM's I hear the sound of water trickling in my dash. My original thought was that I had air trapped in my coolant system, but I have followed the directions I found on here for purging the system and the sound is still there. I know that the hot water valve under the hood is stuck and does not move when I change the temperature selector from hot to cold (I do hear the "flapper" move though). I do get warm air from the vents when I run the fan with the selector on hot, though not as warm as I would like. Does anyone have any ideas about what might be going on?
Thanks in advance,
Rick
Old 01-04-2013, 03:00 PM
INFINITY's Avatar
unclip the heater valve selector wire from the valve on the engine side of the firewall and manually move the valve open or closed and see if the sound goes away. start at that valve first
Old 01-04-2013, 03:12 PM
B-Fake's Avatar
I hear the same thing in mine except mine only does it between 2-3k RPM in first gear pulling out of the driveway in the morning, after that, no noise.
Old 01-04-2013, 03:14 PM
That is a great idea. It is frozen, but I can just bypass it.
Old 01-04-2013, 04:15 PM
lobukbuild's Avatar
yes but you will have no control from inside the truck. it wont hurt or damage anything though.
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
zombie_barbarossa
10-02-2015 10:54 PM
Jdgarrison
10-01-2015 05:22 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Waterfall in my dash
