Water Pump Copper spray gasket and studs?
Old 10-15-2015, 08:02 AM
Obmi's Avatar
Question Water Pump Copper spray gasket and studs?
So i'm getting ready to install the water pump on the timing chain cover. And I found 3 studs, I don't see this in the manual. Did someone change this or do i need to replace it whit the right bolts.
I can't find were i read it was ok to use copper spray gasket to coat paper gaskets and to use ultra gray when i install them. So is this ok? I have 2 other i can use if i screwed it up.
Old 10-15-2015, 09:04 AM
DemonRunner's Avatar
I put the gasket on with nothing on it and no leaks, 3 years ago , Studs are correct just transfer them to the new cover.
Old 10-15-2015, 11:18 AM
wyoming9's Avatar
Red face
I use a light layer of the permatex ultra blue
I think I have studs on like all but one hole been so long I can`t remember
gibbonsballer10
10-26-2023 07:13 AM
Corvoid
12-11-2015 11:21 AM
JookUpVandetti
09-24-2015 08:56 AM
PBRaddict#1
09-22-2015 07:50 AM
tallsasquatch
09-20-2015 02:48 PM
Quick Reply: Water Pump Copper spray gasket and studs?
