Warmup rpms?
Old Nov 7, 2007 | 01:02 PM
mtrdrms's Avatar
Warmup rpms?
Im trying to find out what everyones rpms get up to during warmup. I think my truck (90 22re) goes abnormally high at 2000 rpms but I just cant seem to find anything wrong. So is 2000 rpms during warm up normal?
Thanks
Andy
Old Nov 7, 2007 | 01:05 PM
Justinvd's Avatar
my 88 was idoling at 2500 before. It prolly shouldn't be idoling higher than 1500 even during warm up.
Old Nov 7, 2007 | 01:17 PM
jason191918's Avatar
when it's really cold out mine will hit 2000 for a lil bit. don't know if that means it's normal though...
Old Nov 7, 2007 | 01:34 PM
algranger's Avatar
i dont know what normal is but mine is around 1600, i think that might even be a little high but not sure
Old Nov 7, 2007 | 01:52 PM
mtrdrms's Avatar
So does anyone know how or why mine would be so high?
Old Nov 7, 2007 | 04:13 PM
bigdaddy87547's Avatar
my 95 does around 2000. now i know for a fact that i have a vacuum leak, the problem is finding it. i am hoping that this is my culprit.... also, if i press the throttle lever under the hood down, she goes down to about 1100+-. i hope it has nothing to do with the cable though.
Old Nov 7, 2007 | 04:35 PM
it could be a vacuum leak (you can find it by using a propane torch that is not lit and go over the engine until your idle spikes), or you IAC could be screwy. There is no adjustment on the EFI. You can do an Ohm test to see if the controller is any good
Davebarbier
Nov 3, 2015 03:28 PM
Flightguy
Oct 2, 2015 05:34 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
shredder4286
Oct 1, 2015 01:09 PM
