"Wandering" mixture screw
I have a 1993 Toyota Pickup. 22RE.
the idle had been getting rougher with the cold. It would high idle at 2100 rpm on a cold start and began surging when warm.
I adjusted the screw on the top of the throttle body and my idle was PERFECT. Cold idles never exceeded 1800 rpms for more than a few seconds.
However, coming to a stop sign or two lately the idles been chugging away at about 450 rpm. I'll stop and get out, pop the hood and adjust the screw with my handy-dandy glove box gerber multitool.
it'll be fine for a few minutes, hours or days... but it soon wanders again requiring adjustments.
What do you recommend I use? a washer? loc tite?
There is an O-Ring on that adjustment screw and yours is probably dry-rotted. I had the _exact_ same issues you describe after my recent rebuild. Surging idle, and constant re-adjustment of the idle screw. It'd back nearly all the way out sometimes which is what led me to understand it has an O-Ring.
I replaced the O-Ring and it is solid now. If you don't have - or can't find - an O-Ring, get it to where you like it (warm), and then smear some heavy grease around it and that will at least slow the movement. Not elegant, but will work.
Yeah, the rubber gasket on the mixture screw eventually turns to stone.
Chip it all out and go to your local NAPA/Autozone whatever and ask them to find you an injector o-ring that fits right. The local NAPA did it for free for me.
kawazx636
10-06-2021 03:03 PM
zytra
01-24-2019 03:16 PM
hiluxinargentina
09-30-2015 05:51 PM
JookUpVandetti
09-30-2015 08:58 AM
