WabFab Bikini top finally installed!!
Old 08-14-2007, 06:36 PM
Staff
DeathCougar's Avatar
Finally got her installed. Instructions were straightforward, once I figured out how the top fit down into the channel. The instructions should read: "Flip the top over dummy, there is a plastic strip that fits down into the channel deerrrrr"
Here she is in all her glory!
Here is how I chose to attach it:
I did not want to screw those silly brackets into the body, and ruin the flow of the sheet metal. Besides, Im not a fan of rust. This way, the gate does not contact that strapping, and its at the correct angle to get the top to pull tight. Just gotta shut it slow so it doesn't rattle and risk cutting the strapping.
I also took the liberty of showing the tools needed: 10mm, 12mm, and 16mm sockets, and a philips screwdriver. Thats it!
All in all, high quality, great instructions, and really nice fit and finish!
Old 08-14-2007, 06:38 PM
bballchrism's Avatar
nice i need to get 200$ so i can get one
Old 08-14-2007, 06:39 PM
881stGenRunner's Avatar
I like your idea of using the tail-gate latch. When i had my bikini on, i went ahead and drilled those holes. The bikini never quite got as tight as it need to be. Good job it looks good.
Old 08-14-2007, 06:42 PM
4runnerx3's Avatar
What about the tie down loops on the floor?
Old 08-14-2007, 06:44 PM
colsoncj's Avatar
wow that is a clean runner! very nice!
Old 08-14-2007, 06:45 PM
Staff
They are too far forward. The plastic adjustors on the strapping are sewn pretty far down, so it doesn't really work very well. Besides that, it tends to pull it down at too much of an angle, which makes it look bad anyway. Doesn't really flow with the body lines of the truck.
Old 08-14-2007, 06:47 PM
Staff
140K original miles, got it with 137K abd a bad motor...found a bunch of sand down it DOH! I have spent many hours and dollars getting her back to stock since the previous owner painted many plastic parts Krylon black....and didn't use flexible plastic paint so the paint was chipping off. ICK!
icentropy
09-16-2020 02:47 PM
coryc85
09-09-2015 06:24 AM
09-04-2015 09:27 AM
tj884Rdlx
08-28-2015 12:04 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: WabFab Bikini top finally installed!!
