W56 Transmission Assembly Help!
Old 05-04-2016, 12:17 PM
UteRunner's Avatar
Exclamation W56 Transmission Assembly Help!
After replacing the input bearing, seals, and gaskets, I reassembled everything but I don't seem to have something lined up properly. I tried rowing through the gears before I threw it back in the truck and no joy. I can't remember if I had it in gear or neutral when I took it apart. I'm assuming it has to do with the gear and gear selector shaft alignment. Yes, I've searched. Help a noob out!
Old 05-04-2016, 12:50 PM
UteRunner's Avatar
I'm not sure how this rod was installed when I tore it apart.W56 Transmission Assembly Help!-20160504_144515.jpeg
Old 05-14-2016, 08:32 AM
UteRunner's Avatar
Figured it out. The lower shift fork notch is reverse and it has gotten pushed forward. Once I moved it in line with the other fork it all worked perfectly. Transmission is back in and working just fine.
chicago60647
05-09-2016 11:59 PM
bledsoeyota
04-05-2016 05:36 PM
mikaelm123
04-05-2016 12:57 PM
ghostmoney
04-05-2016 08:03 AM
Ridge
03-09-2016 08:47 AM
Quick Reply: W56 Transmission Assembly Help!
