vibration at 50 mph
Old 09-06-2006, 06:15 AM
dougm395's Avatar
vibration at 50 mph
i have a vibration at 50 mph in either 4th or 5th gear . ive replaced u joints and center support bearing
Old 09-06-2006, 07:07 AM
norcalsvx's Avatar
are the tires balanced?
Old 09-06-2006, 10:16 AM
Saint_Berzerker's Avatar
When you put the ujoints on, did you take the slip yoke out at all? You could've put it in a tooth or so off. Your driveshaft could be out of balance. Or you have too much front end lift and the ujoint angles are too much. There's a thread on here somewhere about that, do a search.
Also, could be your driveshaft. I was getting a bad shake at about 50, and I changed the ujoints and that got rid of a lot of it, but I still have the shakes a little bit, but I'm pretty sure it's my driveshaft.
Old 09-06-2006, 07:44 PM
86SR522REEFI's Avatar
I have never been in a car that didnt shake at 50 mph, check the balance. and check all of the nuts and bolts. Has it been in an accident?
Old 11-04-2006, 06:04 PM
95ToyotaPU007's Avatar
So what was it? or are you still driving your rig around with the shakes?
Flightguy
10-02-2015 05:34 PM
kbpickens
10-02-2015 03:37 PM
hiluxinargentina
09-30-2015 05:51 PM
JPV
09-28-2015 03:15 PM
Odin
09-26-2015 06:56 PM
Quick Reply: vibration at 50 mph
