V6 Rough Idle
Old 12-19-2006, 03:00 PM
Th3duke's Avatar
V6 Rough Idle
I've recently purchased a 1990 pickup with a V6; it was running kind of rough, and couldn't get the timming adjusted properly. Hence, I adjusted the TPS as per 4Crawler's site... My question is this:
What was your VTA - E2 setting?
My idle appears to be a lot better, but there's still a miss.
I've cleaned the throttle body
Adjusted the TPS
Changed the Plugs
Changed the wires
Changed the Dist Cap
Changed the rotor
Set the base timing to 10
Changed the air filter
Changed the PCV
But it still idles a little rough.
Additionally, when I start it up and it's cold, there's hesitation...
Old 12-19-2006, 03:59 PM
4runnermax's Avatar
LOOKS LIKE TIME TO TO A COMPRESSION TEST AND LEAK DOWN BUT....
BEFORE GOING INTO THAT MAKE SURE NONE OF THOSE FANCY NEW WIRES ARE SHORTING ANY WHERE (LIKE THE EGR, I DID THAT ) ALSO RECHECK EVERTHING YOU DID ALREADY, WOULDNT YOU BE IF YOU FOUND OUT YOU MISSED SOMTHING SIMPLE
Old 12-19-2006, 04:01 PM
4runnermax's Avatar
ALSO PUSH ALL THE CONECTERS ON YOUR WIRES IF NO HELP CONFIRM YTOU HAVE GOOD SPARK AT ALL WIRES. IF YOU GOTO DO THE COMP AND LEAKDOWN TEST CHECK FIRE, AND GAP AT EACH PLUG AS YOU PULL THEM.... wHAT PLUGS DID YOU USE PLEASE DONT TELL ME BOSH (ONLY PUT NGK OF DENSO IN YOUR YOTA OR YOU COULD BE SORRY)
Old 12-19-2006, 06:31 PM
Elton's Avatar
no freakin caps
Old 12-19-2006, 06:40 PM
ChickenLover's Avatar
At what rpm is your idle?
Old 12-19-2006, 07:25 PM
4runnerx3's Avatar
have you checked the injector seals? One of my 22re's started missing the other day and found one spark plug tip came loose where it is threaded on that the plug wire snaps onto.
Old 12-20-2006, 10:35 AM
Th3duke's Avatar
rpm runs at about 850 when warm, but when it gets hot it'll run at about 600.
Old 12-21-2006, 05:41 AM
Babypig's Avatar
Did you clean out the IAC valve on the side of the throttle body? Oil gets in there and causes an idle problem sometimes.
Old 12-21-2006, 07:24 AM
Th3duke's Avatar
Nope... I didn't clean that. just unscrew the plate and spray some TB cleaner in there? Anything delicate in there that I should be aware of?
Old 12-21-2006, 03:59 PM
Babypig's Avatar
Just some throttle cleaner and a q-tip or a rag if its dirty. See that your from cantley. I just moved back west from Ottawa.
Old 12-22-2006, 03:30 AM
Th3duke's Avatar
Hey, that seemed to help a lot! I'll take it for a nice long drive later today and see what she does. Yeah, I'm 10 minutes away from Ottawa, small world... I'd love to see the western provinces.
Thanks again for the help.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
1992pickupSr5
05-09-2019 08:44 AM
TACOJO
11-27-2015 05:26 PM
markwink
08-18-2015 12:38 PM
Quick Reply: V6 Rough Idle
