Update: OD light flashing starting off in 3rd gear
Old 08-30-2006, 02:01 PM
nineball's Avatar
Took it in and had the codes ran on the tranny, turns out all the solenoids and the speed sensor are not getting power The tech at the tranny shop said I probably have a bad ECM although he didn't have time today to trace the wires coming out of the ECM to check for output. He looked underneth and couldn't find a break in the wiring harness between the tranny and the fuses, any thoughts???
Old 08-30-2006, 04:44 PM
nineball's Avatar
anybody????
Old 09-07-2006, 09:28 AM
nineball's Avatar
tried another ECM and still the same problem , traced all the wires and checked for continuity and there all good. Pulled the pan and all the solenoids click when given 12V. For some reason the computer is not telling the tranny to downshift to 1st gear. I need some help guys, I have had two tranny guys and toyota tech guys look at this thing and they are stumped
Old 09-08-2006, 08:28 AM
jasond's Avatar
Which trans do you have, what codes do you have (be specific)...1992 4runner, v6 correct?
Old 09-09-2006, 07:25 PM
nineball's Avatar
a340h, codes are for all four solenoids and both speed sensors.....
Old 09-09-2006, 08:27 PM
yota_krazy's Avatar
ok so is the ecm recieving the power to supply voltage for the solenoids? It sounds like its time for an electrical troubleshooting guide with some detailed pics of the circuit you are working on.
Team420
01-12-2021 04:57 PM
Ichneumon
09-27-2015 04:21 PM
rbravo1
06-29-2015 01:34 PM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: Update: OD light flashing starting off in 3rd gear
