Two pinion, how can you tell.
Old Jun 23, 2008 | 04:48 PM
Junkers88's Avatar
My 4.56 rear got here today (counted the teeth and I've got 9 on the pinion and 41 on the ring) now I need to figure out how to tell if I've got a 2 or 4 pinion.
Can I look inside and see the pinions? I only see one cross pin if that helps.
edit. This might help
Old Jun 23, 2008 | 04:52 PM
JamesD's Avatar
If you can see the spider gears and the cross pin it is a two pinion.
James
Old Jun 23, 2008 | 05:15 PM
Junkers88's Avatar
James
Thanks for the reply. Now it's off to Aussie to order a locker, now that I know it'll go in there.
See ya!!
Old Jun 23, 2008 | 05:21 PM
86tuning's Avatar
You've shown a picture of a 2-pinion diff. 4-pinion diffs have an enclosed construction, where you cannot see any of the gears inside the diff.
Old Jun 23, 2008 | 05:38 PM
Matt16's Avatar
Whoa, I didn't know you could get a OEM 2 pinion 4.56 diff. Are they simply extremely uncommon? From what truck is that diff from?
Old Jun 23, 2008 | 06:19 PM
HAVOC's Avatar
scroll down to see a 4-pinion diff
http://www.gearinstalls.com/flexor1c.htm
Old Jun 23, 2008 | 06:24 PM
corax's Avatar
the pinions are the 2 gears on the ends of the cross pin
2nd Gen 4cyl 4runner with factory 31" tires I thought -- G252 axle code
Old Jun 24, 2008 | 05:45 AM
Junkers88's Avatar
Matt,
This is the rear from a 1994 Runner with a manual tranny and 4 cyl motor. I don't know if these are hard to find or not. The good thing about this is now I can drop in the Aussie and enjoy all the stuff you talk about with a locker.
The front is on the way and it's a non ADD so I don't have to do anything with it other than another locker and install.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
Odin
Sep 26, 2015 06:56 PM
justdifferentials
Sep 5, 2015 06:52 PM
moparbay
Sep 3, 2015 12:48 PM
