Which Tru Trac model for IFS diff?
Old 12-31-2007, 04:59 PM
plasticboater's Avatar
Good evening, I have an '87 4Runner and I am interested in a Tru Trac LS for the front diff. There are two model numbers: one for a 45mm hub and one for a 50 mm hub. Does anyone know what size hubs an '87, 22re, 5 speed with manual hubs has? Thanks. Mike
Old 12-31-2007, 08:08 PM
InternetRoadkill's Avatar
I've never heard of the truetrac having a hub size. You want the one for the 7.5" IFS. There are two versions. The difference is the number of splines on the axle shafts and the axle diameter. For the 22RE engine, you'll probably want the DET911A445 model.
If you want to be certain, pull the axles out and measure them and count the splines.
Old 12-31-2007, 10:03 PM
drew303's Avatar
wtf, ive never heard of that kind of description.
Toyota IFS manual hubs are the same from 86' to 95.5 and the differentials are all 7.5". 27 spline axles.
http://store.summitracing.com/partde...5&autoview=sku
thats it at summitracing
the info is conflicting though since it says 30 spline then it says 27 spline. I would call them to make sure you get the right one.
The 8" toyota dif is 30 spline so when a description says pickup/4runner front it means 85 and older. The front differential in the solid axle is identical to the rear. fyi
I have a Truetrac in my rear and have plans to transfer it to my front axle when I SAS and put a full detroit in the rear. I like the truetrac a lot.
Old 01-01-2008, 05:45 AM
jjrgr21's Avatar
one's for a pick-up and the other a taco. not sure which though///
nope, one is for manual hub[342], other is for all others[565](ADD)
Old 01-01-2008, 02:57 PM
Post
Thank you to all who replied. I found the info at: JawsGear.Com; #342 - V6, #445 - 4cyl. Mike
Old 01-01-2008, 03:06 PM
Targetnut's Avatar
The trutrac for the rear has 100ft/lbs of preload, I believe the one for the front does not.
My experience with JAWS gears was a negative one, so it would be my recommendation to find a different supplier.
Old 01-01-2008, 04:26 PM
ewong's Avatar
NWOR lists a split at 89 (akak Gen 2 vs Gen 3)
http://www.northwestoffroad.com/parts/diff_detroit.html
Me guesses you want the smaller one.
IMHO call the supplier you plan to purchase from ant let them figure it out (if they are wrong they have to eat it)
Old 01-02-2008, 05:50 AM
Thanks Targetnut and ewong. I had planned to buy from 4WheelParts. JawsGears was the only website that gave specific applications for the two part numbers. The "driveline" guys at 4WPs had all gone home when I called the tech line Monday evening. Mike
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
89fourrunner
02-17-2016 06:52 AM
boogiewoogie
08-29-2015 01:03 PM
dfarr67
07-30-2015 07:08 AM
scottyg486
07-19-2015 05:34 PM
Quick Reply: Which Tru Trac model for IFS diff?
