Trouble with Timing.
Old 01-03-2009, 10:35 AM
wbthornton88's Avatar
Ok I am having trouble getting my timing set on 95 3vze. This illistration shows before crank and after. Basically the truck cranks and runs like crap. I was wondering if twisting the crank counterclockwise before lining up could have caused a problem? Notice after the engine is turned over the 2 cams still line off and the crank pulley gear is off to the right and diagnally up.
Old 01-03-2009, 11:23 AM
Could this be it? I think I found my problem. I have been lining the square part on the crank gear up instead of the mark on the base of the gear with the oil pump alignment. According to this photo there is a good 15 degrees difference. Do you guys think this is why my truck was running so sloppy? I attached a image below.
Old 01-03-2009, 11:25 AM
ScottyC's Avatar
You line up the marks, not the square portion.
Old 01-03-2009, 12:54 PM
dieselloco427's Avatar
yeah, that would be your problem. I just did the timing belt and waterpump on my 3.0 and those pulley marks have to be aligned perfectly with the ones on the timing cover and with the ones on the belt (if you got a toyota belt)
mulewright
10-03-2015 02:47 PM
voiddweller
10-02-2015 07:47 AM
Matthew Perez
09-28-2015 05:43 PM
Boomer8404
09-17-2015 07:59 AM
128keaton
09-03-2015 05:09 PM
Quick Reply: Trouble with Timing.
