Transmission removal woes...input shaft siezed?! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-10-2009, 09:19 PM   #1 (permalink)
4WDarren's Avatar
Exclamation Transmission removal woes...input shaft siezed?!
1990 4Runner, 22RE, G58 5spd.
Currently am in the process of doing my clutch, rear main seal, etc.. Not my first time doing this job (had the tranny in my '84 pickup in and out many a time), but it's definitely been the worst removal I have experienced... and this is with all the right tools! (good tranny jack, etc..)
I can only get it to slide back about an inch and a half or so (can just see the flywheel teeth), and then it stops. I should mention that even to get the tranny to seperate this much took some good force (prying between the bellhousing and engine-transmission stiffeners). There's lots of freedom for the tranny to move up/down & fore and aft at this point, but it is obvious that something is hanging up in the center somewhere. Even with two of us pulling on the tranny, it does not budge any more.
Is it possible that the input shaft is somehow worn or siezed in the pilot bearing, preventing any further removal?
__________________
'90 Rusty 'Runner in the works
I sold my Taco for this??!!
4WDarren is offline
Old 06-10-2009, 10:21 PM   #2 (permalink)
abecedarian's Avatar
Since the pilot bearing is about 3/8" thick at most, having 1+ inch of motion means it's more likely damage to the input shaft could keeping the clutch disc from sliding off the input shaft. Or something else is interfering with motion... shift levers, cables, electrical, clutch slave cylinder piping, drive shaft still connected? Not saying those are the problem but sometimes we all get scatterbrained and overlook the obvious.
If nothing else is the issue, do you have access to the pressure plate to flywheel bolts? I'm thinking you can rotate it around and loosen the pressure plate from the flywheel.
__________________
Why do people run the dishwasher and walk the dog?
I would love to go look but I'm too busy sorting my random coin flip collection.
abecedarian is offline
Old 06-10-2009, 11:25 PM   #3 (permalink)
4WDarren's Avatar
Yeah, I had checked and double checked to make sure everything was disconnected and clear...no problems there. Unfortunately I can't quite get to the pressure plate bolts...tranny needs to go back more for that to happen (but I like the way you think!)
__________________
4WDarren is offline
Old 06-11-2009, 03:48 AM   #4 (permalink)
corax's Avatar
do you have enought room to get some spray lube in on the input shaft? maybe slide the trans back and forth a few times to get whatever to loosen up?
__________________
-Keith- kb3scj
'88 4runner SR5 - 3.0 7MGE eng swap - Marlin HD W56 - 4.56 V6 Thirds - '82 Toyota Celica Supra LSD up front - 33x10.5 BFG KM2's - NWMP Aux Gas Tank - home fab front and rear bumpers - Hannemann fenders - OME Dakar rear springs w/ Bilstein 5150 reservoir shocks Garage Thread
"Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
corax is offline
Old 06-11-2009, 04:32 AM   #5 (permalink)
Perhaps your pilot bearing is fused to the end of your input shaft, and when you pried the tranny back the bearing came out of the flywheel and is now stuck on the end of the shaft and it won't fit through the hole in the clutch disc. I've never seen that happen, usually they are stuck in the flywheel, but hey you never know.
Maybe try spray lube like corax suggested, but I don't know if you could even get it in there behind the clutch.
coryc85 is offline
Old 06-11-2009, 02:48 PM   #6 (permalink)
corax's Avatar
or a chain wrapped around the transfer case and attached to the bumper of another truck . . . make sure you chock the wheels on your rig first though
__________________
-Keith- kb3scj
corax is offline
Old 06-11-2009, 03:30 PM   #7 (permalink)
bigtrucknwheels's Avatar
Send a message via AIM to bigtrucknwheels
Quote:
Define Eastern PA
I dunno what to tell the OP, but I am watching this thread, as it is intriguing. Sorry haha
__________________
'03 Camry LE. Fwd/I4/Auto. Got the car for $2200 bucks. Rough around the edges, but in decent shape. Gas miser/beater car. :D
'97 4Runner SR5 V6. 4wd/V6/5spd. E-Locked. Going in storage while awaiting repairs.
'90 Pickup Xtra Cab DLX. 4wd/V6/Auto. FOR SALE NOW, PM!
'89 Pickup Std. Cab DLX. 4wd/I4/5spd. 3" BL. In storage while awaiting repairs.
'90 4Runner SR5 V6. Complete Part Out! Click or PM!
bigtrucknwheels is offline
Old 06-11-2009, 03:50 PM   #8 (permalink)
corax's Avatar
Quote:
Originally Posted by bigtrucknwheels View Post
Define Eastern PA
0.5 hrs NNW of Allentown, but we're moving somewhere in between East Stroudsburg/Hazleton/Wilkes Barre in a few months if our offer is accepted . . . I'm actually driving out to Sunbury tomorrow on business before heading down to Coleman's Surplus
__________________
-Keith- kb3scj
corax is offline
Old 06-11-2009, 06:26 PM   #9 (permalink)
kenbo53's Avatar
probly not your problem since uve done this on toyotas befor but when i did my clutch i had simmilar problems. being that id worked on nothing but old gm stuff befor this where the starter is atached to the block unlike the toyota being atached to the transmision. unfortunatly i didnt discover this untill the lower mount broke off the starter from all the frustrated prying action
__________________
93 pu v6 5speed rear lockright 31mts
87 xtracab mudtruck welded rear 31x12.5 boggers
80 pu for parts pm me if ur looking for glass or interior parts
71 gmc 3/4 ton
05 gmc canyon
kenbo53 is offline
Old 06-11-2009, 06:49 PM   #10 (permalink)
Lumpy's Avatar
I don't know what your issue is, just subscribing so I know if or when I run into this.
BigTruck, Croax, I have kin in Lewisburg, might try to get a hold of ya if I have time when I head out that way again.
__________________
"""The Official Unofficial build thread!"""
92 std cab
22RE 5 spd 4x4
268 Engnbldr Cam
3"Intake w/ cone
31X10.5----4.10's
Purchased 11/08 @125K miles
Great find first project Toy
95 SR5 4Runner
3.Slow Auto :-( 4x4 (5 spd someday)
33X12.50----4.88's
LC Coils She's raked a bit now
5/09 Traded a 1980 CB 750 for it!!! Yeah for me...
106K miles
IFS Club #2
Quote:
Originally Posted by tc View Post
Yeah, pretty sure they're gonna rub like a fat chick in cordurouy
Lumpy is offline
Old 06-11-2009, 06:51 PM   #11 (permalink)
cool beans. I am building a mental list of all the PA members (not too many haha) on this site, who knows, maybe we could orchestrate a wheeling meet this summer like all the west coast folks do.
__________________
Old 06-12-2009, 08:34 PM   #12 (permalink)
4WDarren's Avatar
Yeah, the idea had been discussed Unfortunately, no good way to get a direct pull on it. A friend might drop by with a come-along or two, so we'll see if that works. Tonight I have some time to wrench on it, so we'll see what happens. I will definitely post some pics when I finally get the stupid thing out.
(I'm fairly convinced it's the pilot bearing siezed onto the input shaft)
__________________
4WDarren is offline
Old 06-15-2009, 12:03 AM   #13 (permalink)
4WDarren's Avatar
FINALLY!!! Got the stupid tranny out! As promised, here's some pics of the final solution. As I was certain that the pilot bearing was stuck on the input shaft, the only logical next step meant to get the pressure plate & clutch disc off the flywheel to make some room to pull the tranny back.
I've got another tranny lined up to install, and as there was no other way of accessing the pressure plate bolts, I got down to business and made an access hole of my own:
At least now I could get the pressure plate and clutch disc to slide back enough to create room to pull the tranny free, and what do ya know, my theory was right:
Stupid pilot bearing! Argh!
For fun, I wanted to see how badly this thing was siezed to the shaft. It took my large puller to pull the stupid thing off, and it fought me all the way to the end:
Good grief! I've never heard of this happening before, but as they say, there's a first time for everything. Let's hope it's the last.
__________________
4WDarren is offline
Old 06-15-2009, 12:10 AM   #14 (permalink)
Tubbyfatty's Avatar
Send a message via AIM to Tubbyfatty
Wow, what a pain.
I hear putting some anti seize on the shaft works to prevent this. I could be wrong tho.
__________________
94 4runner / SR5 / 3vz-e / 5spd / 4x4 (duh) / Mudcat EXT 30x 9.5R15s / Marlin Crawler HD Clutch / ISR / Hella 700FFs 100w bulbs / 2 10'' JBL subs / ported sub box / kicker mono amp / Pioneer DEH-P490IB / sitting 1-1.5'' below factory, thanks butt sag...
Blown head gasket 12-06-2009, 212k miles
Re-assembled and running 2-2-2010
Tubbyfatty is offline
Old 06-15-2009, 03:55 AM   #15 (permalink)
corax's Avatar
Quote:
x2, sounds like a good idea and just might save you a bit of grief later on
__________________
-Keith- kb3scj
corax is offline
Old 06-15-2009, 05:42 AM   #16 (permalink)
nice solution. I am glad it worked out for you!
__________________
Tags
anti, antiseize, bearing, clutch, flywheel, input, pilot, removal, seize, seized, shaft, stuck, supra, trans, transmission, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Length of a W58 input shaft? T-1000 86-95 Trucks & 4Runners 0 05-19-2009 05:36 PM
Worn input shaft slothman 86-95 Trucks & 4Runners 5 12-18-2008 12:13 PM
Help HOW do you plug the Transmission during Drive Shaft Removal simpsons721 86-95 Trucks & 4Runners 6 08-08-2008 04:28 PM
Rear Main or Input shaft rowdy235 Pre 84 Trucks 2 10-19-2007 10:26 PM
Input shaft, end bearing?? Sbrut95 95.5-2004 Tacomas & 96-2002 4Runners 5 02-10-2004 09:06 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
