transfercase removal
Old Sep 11, 2008 | 03:28 PM
Dipstik_90's Avatar
I searched the forum but found nothing. I found a t-case in the local pick and pull, and was wondering if it's possible to remove the t-case without removing the tranny as the Chiltons manual says to. Also the truck is an '86 will this t-case work for a dual setup in my '90 Pickup? The '86 is a 22re
5spd and so is my truck.
Old Sep 11, 2008 | 03:36 PM
DeathCougar's Avatar
You need a top shift t-case from an 85-88 truck, so yea its the one you want
Old Sep 11, 2008 | 04:02 PM
BLKNBLU's Avatar
IIRC thats 85-88 EFI truck. Please correct me if I'm wrong. The OP is still good to go.
Old Sep 11, 2008 | 04:06 PM
that is correcto. Unless someone swapped in a W series trans into their carrbed truck, or vise versa
My 87 EFI has a Turbo trans in it!
Old Sep 11, 2008 | 04:25 PM
mr toytech's Avatar
yes you can remove the transfer case without removing the tranny.
Old Sep 11, 2008 | 09:01 PM
Dipstik_90's Avatar
Ok that's all I need to know. How do I tell if it's top shift or not? I'm heading there tomorrow, also going to grab the rear 3rd member out of a v6 4runner they got for a spare.
Old Sep 11, 2008 | 09:04 PM
cutboggers's Avatar
If it has a shifter hanging out of the top.
If not it will have two lil shifter rails coming out where it would go to your tranny.
Old Sep 11, 2008 | 10:05 PM
toyNG's Avatar
just curious...how much did you pay for the tcase? I might be in the market for one soon.
Old Sep 11, 2008 | 10:35 PM
dropzone's Avatar
Fossilized
take out the shift lever, remove the snap ring to do so. You won't be able to slide the TC back far enough if you do that. I
Old Sep 12, 2008 | 07:20 AM
Dipstik_90's Avatar
I don't know exactly how much yet it hasn't been pulled.
Old Sep 12, 2008 | 07:54 AM
muddpigg's Avatar
If I was you discuss price before you pull it. That way you have more room to bargain. The junk yard knows that if you pull it your apted pay more since you've already committed to it.
Old Sep 12, 2008 | 08:40 PM
Dipstik_90's Avatar
The ones up here aren't really strict like that. It's a giant yard with rows of cars thats it. There's really no inventory just, "I think we got one of those go check around"
Old Sep 13, 2008 | 03:35 PM
Dipstik_90's Avatar
Transfercase $40 YAHOOO!!!!!
I think it's the right one, the shifter is on the top of the reduction box.
Old Sep 13, 2008 | 05:29 PM
Dipstik_90's Avatar
So which one do I use for the "rear" case? The one I have in the truck now or the one I just bought?
Old Sep 14, 2008 | 08:20 AM
toyNG's Avatar
$40 sounds like a great price! makes me really want to set up a dual t-case...
Old Sep 14, 2008 | 04:06 PM
Yopar's Avatar
Someone that's done it can chime in here, but I think you put the one you just bought in front of your original t-case (using an adapter, +you only use the front 1/2 of the new unit). Your original t-case will sit about 6.5" back to the rear, so shortening the rear driveshaft and lengthening the front will be needed. I think you can choose to either use the original cross member mount with or without an additional one to support the added length of the set-up. Marlin Crawler has a page on his site that shows the adapters and goes through how it all works.
1uzRunner
63
Nov 10, 2018 03:58 PM
gyroscope7
7
Sep 27, 2015 08:39 PM
LotOMiles
Sep 14, 2015 11:45 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
gp66
Sep 7, 2015 08:29 AM
